You're thinking backwards. The purchased parts may be job material requirements. (Otherwise, why buy them?)
Each job material must be associated with an OP (and therefore a resource -that can have a backflush whse/bin set up for it).
--- On Mon, 11/3/08, Jonathan Lang <lsbestinc@...> wrote:
Subject: Re: [Vantage] Stock Location and Backflush
Date: Monday, November 3, 2008, 3:26 PM
I checked the resource group and found a few default backflush bins assigned and I did remove them. But that solution does not affect the Purchase Parts. There are no resources assigned to Purchased Parts.
To: vantage@yahoogroups .com
Date: Monday, November 3, 2008, 12:04 PM
Check your resource group and see whether or not you have a default backflush bin set there. This will override anything on the part record
--- On Mon, 11/3/08, Jonathan Lang <lsbestinc@yahoo. com> wrote:
Subject: [Vantage] Stock Location and Backflush
Date: Monday, November 3, 2008, 1:01 PM
Good Afternoon all,
Â
I have a riddle for you all and maybe you can help me solve. My default location is STK. I have set Primary Bins up for parts, but for some reason when backflushing occurs some of the parts go into STK even though a Primary bin is specified. Any ideas?
Â
Jonathan LangÂ
Oil Rite Corporation
Sr. Network Administrator
Ph: (920) 682-6173 Ext: 126
Fax: (920) 682-7699
