Subcontracted Operations
Hi Len,
And I happened to mention that to Gerry off list....when you have many
jobs using the same service, it is a much better route, but it means
updating all BOMs using that service and then creating the POs isn't a
big deal.
Our production is still small enough that we use the other route at the
moment. But they are aware what needs to be done if production ramps up
again (hopefully soon!).
M. Manasa Reddy
manasa@... <mailto:manasa@...>
800.852.2325
630.806.2000 ofc
630.806.2001 fax
www.weldcoa.com
Of Len Hartka
Sent: Wednesday, January 20, 2010 4:44 PM
Subject: RE: [Vantage] Re: Subcontracted Operations
Good Day M:
If you want an outside-the-box idea......
One thing we have done is to create a Part# ( normal stockable Part#
) for the operation, so the plating for 10027 is PL10027; then, we
create a BOM consisting of the Casting-Part#'s and the PL10027-Part#. A
normal PO gets released for PL10027; then, when the PO is received, the
PL10027 goes into stock and issued to the WO. When the WO is closed, the
cost of PL10027 gets captured.
Actually we do not have a machine shop, so we have "M" numbers for
the machining for many parts. This allows us to Quote the "M" numbers,
track usage, query in ACT, query in ITHistory, etc.
I should mention that we are going to E9 and will probably start
dong the normal "Outplant" operation to a WO system. I got out-voted.
But we just did our first training, so there is still a chance I might
save the system.
len.hartka@... <mailto:len.hartka%40sunautomation.com>
Leonard C. Hartka, IT Director\ERP Manager
Sun Automation Group
66 Loveton Circle
Sparks, Md. 21152
410-329-3560 ext. 120
410-329-3564 FAX
443-255-7192 Work Cell
www.Sunautomation.com <http://www.sunautomation.com/
<http://www.sunautomation.com/> >
Behalf
Of Manasa Reddy
Sent: Wednesday, January 20, 2010 10:54 AM
Forgot to mention we send a PO for our top level part....we do NOT
create separate part numbers for the subcontract work. Easier to track
through the system - at least for us it is easier.
M. Manasa Reddy
manasa@... <mailto:manasa%40weldcoa.com>
<mailto:manasa@... <mailto:manasa%40weldcoa.com>
<mailto:manasa%40weldcoa.com> >
800.852.2325
630.806.2000 ofc
630.806.2001 fax
www.weldcoa.com
Behalf
Of Manasa Reddy
Sent: Wednesday, January 20, 2010 9:50 AM
When you create a subcontract op, you create a PO for that op to send
the parts out....when you "receive" that PO, that is when the costs hit
the job.
M. Manasa Reddy
800.852.2325
630.806.2000 ofc
630.806.2001 fax
www.weldcoa.com
Behalf
Of Gerry Loranger
Sent: Wednesday, January 20, 2010 7:08 AM
How do you report the production?
Gerry
Behalf Of
DONNA RADIKA
Sent: Tuesday, January 19, 2010 4:30 PM
Subject: [Vantage] Re: Subcontracted Operations
The subcontract operation in Vantage works great. We did add a resource
group called "Outside Process" that we associate with any subcontract.
This e-mail and any attachments may contain proprietary and/or
confidential information. If you are not the intended recipient, please
notify the sender immediately by reply e-mail or at 410-472-2900 and
then delete the message without using, disseminating, or copying this
message or any portion thereof. With e-mail communications you are urged
to protect against viruses.
Hello all. We have a number of manufacturing services that are outsourced, such as, welding, painting and powder coating. I'm considering using a Resource Group to handle outsourced manufacturing processes and would like to know if any of you are using the method to handle these types of operations and how it works for you.
Gerry
This might seem obvious, but did you consider using the Subcontrator operation in Vantage? We use that and it provides great visibility for everyone from Purchasing to Manufacturing to Shipping and receiving. This sure beats the way we used to do it! (Don't ask!)
Doug Oswald
MIS
FLEETOOD
Vantage 8.03.404B
The subcontract operation in Vantage works great. We did add a resource group called "Outside Process" that we associate with any subcontract.
Yes, I've looked at using the subcontract operation. If I understand
correctly, since we don't pay these subcontractors by the hour, someone
would have to take the cost of the services and enter a number of labour
hours equal to the fee. Is that correct? Or is there a simpler method of
entering the actual cost?
Currrently, we use part numbers for outside operations. E-coating, for
example, is $1 a unit. If it costs $50 to powder coat a given part, we add
50 units of the Ecoat part to the BOM. We manually transfer the parts being
coated to and from the supplier's warehouse. I noticed the auto-move feature
in the subcontract operation, that could automate the movement process.
Gerry
djojmis
Sent: Tuesday, January 19, 2010 4:20 PM
Doug Oswald
MIS
FLEETOOD
Vantage 8.03.404B
Gerry
DONNA RADIKA
the job.
M. Manasa Reddy
800.852.2325
630.806.2000 ofc
630.806.2001 fax
www.weldcoa.com
Of Gerry Loranger
Gerry
Behalf Of
DONNA RADIKA
M. Manasa Reddy
800.852.2325
630.806.2000 ofc
630.806.2001 fax
www.weldcoa.com
Of Manasa Reddy
the job.
M. Manasa Reddy
<mailto:manasa@... <mailto:manasa%40weldcoa.com> >
800.852.2325
630.806.2000 ofc
630.806.2001 fax
www.weldcoa.com
Behalf
Of Gerry Loranger
Gerry
Behalf Of
DONNA RADIKA
Thanks Manasa!
Manasa Reddy
M. Manasa Reddy
manasa@... <mailto:manasa%40weldcoa.com> <mailto:manasa@...
800.852.2325
630.806.2000 ofc
630.806.2001 fax
www.weldcoa.com
Behalf
Of Manasa Reddy
the job.
M. Manasa Reddy
800.852.2325
630.806.2000 ofc
630.806.2001 fax
www.weldcoa.com
Behalf
Of Gerry Loranger
Gerry
Behalf Of
DONNA RADIKA
Good Day M:
save the system.
len.hartka@...
66 Loveton Circle
Sparks, Md. 21152
410-329-3564 FAX
len.hartka@...
www.Sunautomation.com <http://www.sunautomation.com/>
Of Manasa Reddy
M. Manasa Reddy
800.852.2325
630.806.2000 ofc
630.806.2001 fax
www.weldcoa.com
Behalf
Of Manasa Reddy
the job.
M. Manasa Reddy
800.852.2325
630.806.2000 ofc
630.806.2001 fax
www.weldcoa.com
Behalf
Of Gerry Loranger
Gerry
Behalf Of
DONNA RADIKA
This e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.
