Thanks to both Todd and Jim for your help on this. I will keep plugging away at it. You can expect more questions from me as I go through it.
Thanks!
Beth
Todd Caughey <caugheyt@...> wrote:
Basically, yes, each report's connection will need to be changed....to work on it. They will still run from within Vantage 6.1 but when running them from the development screen they will run from whatever DB the connection says to use. In addition to the path to the database you also need to change the service name under the Options button.
I still have many Epic52 and Mfgsys60 related reports that run fine from the Vantage menus but need to be changed as I run across them to make changes. So you do not need to change them all...just anything that needs to be changed to reflect new field names in 6.1...of which there are many, especially quantity type fields that now start with "Our".
There is an option in RB to always display the connection box in the developer mode when opening a report which makes it easier to note, and correct, report as you open them rather than getting a connection error message.
-Todd C.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Beth Castillo
Sent: Thursday, August 30, 2007 12:55 PM
To: Vantage Users
Subject: [Vantage] Transferring Report Builder reports from 4.0 to 6.1
We are going from version 4.0 to 6.1 and I need to transfer our reports in Report Builder. I made a new library in the 6.1 Report Builder that I titled "reports61". And I made a new database connection in report builder for 6.1. I am able to create new reports that draw data from the 6.1 database, but I'm having problems with the existing 4.0 reports. They still draw data from 4.0 even when I open them from the 6.1 Report Builder. I tried adding the 6.1 database connection on the 4.0 reports, but it still draws from 4.0. Since we are in the process of upgrading from 4.0 to 6.1, we have both versions on my computer. They are on separate servers. How can I copy these existing reports from 4.0 into my new 6.1 library so that they pull data from 6.1? Do I need to enter a new database connection for each report, and delete the old connection? I am not an IT person so please put it in simple terms so I can understand. I want to be able to run the same report in both
4.0 and 6.1 so that I can compare the output to determine whether or not the 4.0 report structure will work in 6.1. Hope this make sense to someone. I can use any help.
Beth
Building a website is a piece of cake.
Yahoo! Small Business gives you all the tools to get online.
The information contained in this E-mail message and any documents which may be attached are privileged and confidential, and may be protected from disclosure.
Please be aware that any use, printing, copying, disclosure or dissemination of this communication may be subject to legal restriction or sanction. If you think you have received this message in error, please reply to the sender.
For more information please visit www.harveyvogel.com
Thanks!
Beth
-Todd C.
To: Vantage Users
Beth
