The Project:
Create a form that lists current laser table operations. This form also needs a way to log the operations as complete once they’re nested. (Laser Table reports by quantity only)
Work So Far:
Used Job Adjustment screen as a cookie cutter template. Hid all tabs except 2. The labor adjustment tab, referred to as “Op Logger”, and a second tab to keep a list of jobs on. The laser guy enters his job number at the top. This loads job info into the form. He then goes to the Op Logger tab, selects his Assembly and Operation numbers. Clicks “Get Costs” to get data from a query based on standard times and costs and places it into an ultragrid for display.
The Problem:
I created another button and want it to copy the data from the ultragrid into the EpiNumericEditors. Maybe we can even combine this function within the “Get Costs” button, to run the dynamicquery and paste the data with just one click… Anyway, I’ve tried
neLaborQty.Text = this.ugcosts.DisplayLayout.Bands[0].Columns["Run Qty"].ToString();
and
neLaborQty.Text = ugcosts.Rows[0].Cells["Run Qty"].Text;
and
neLaborQty.Value = ugcosts.Rows[0].Cells["Run Qty"].Value;
Here’s pictures of what I’m trying to accomplish.
The list works fine.
The “Get Costs” button works fine.
The"Copy Costs" button fails.
The Emoployee Name appears because I’m pushing plain text to it, not getting from another control or from a query.
Below is the code as it is right now.
// Custom code for JobAdjustmentForm
// Created: 5/10/2019 9:35:55 AM
using System;
using System.Reflection;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Ice.BO;
using Ice.UI;
using Erp.Adapters;
using Erp.UI;
using Ice.Lib;
using Ice.Adapters;
using Ice.Lib.Customization;
using Ice.Lib.ExtendedProps;
using Ice.Lib.Framework;
using Ice.Lib.Searches;
using Ice.UI.FormFunctions;
public class Script
Infragistics.Win.UltraWinDock.UltraDockManager dock;
EpiTextBox tbJobNum;
EpiTextBox tbEmployeeNum;
EpiNumericEditor neLaborQty;
EpiNumericEditor neLaborHrs;
EpiNumericEditor neBurdenHrs;
EpiNumericEditor neLaborCost;
EpiNumericEditor neBurdenCost;
Erp.UI.Controls.Combos.JobAsmSearchCombo cboAsmSeq;
Erp.UI.Controls.Combos.JobOperSearchCombo cboOper;
public void ugupdatecosts()
DynamicQueryAdapter dqa = new DynamicQueryAdapter(oTrans);
dqa.BOConnect();
QueryExecutionDataSet qeds = dqa.GetQueryExecutionParametersByID("Laser_Op_Details");
qeds.ExecutionParameter.Clear();
qeds.ExecutionParameter.AddExecutionParameterRow("JobNum", tbJobNum.Text, "nvarchar", false, Guid.NewGuid(), "A");
qeds.ExecutionParameter.AddExecutionParameterRow("AssemblySeq", cboAsmSeq.Text, "int", false, Guid.NewGuid(), "A");
qeds.ExecutionParameter.AddExecutionParameterRow("OprSeq", cboOper.Text, "int", false, Guid.NewGuid(), "A");
dqa.ExecuteByID("Laser_Op_Details", qeds);
ugcosts.DataSource = dqa.QueryResults.Tables["Results"];
public void ugupdatelist()
dqa.BOConnect();
QueryExecutionDataSet qeds = dqa.GetQueryExecutionParametersByID("Laser_JobList");
dqa.ExecuteByID("Laser_JobList");
uglaser.DataSource = dqa.QueryResults.Tables["Results"];
Object obj = typeof(Erp.UI.App.JobAdjustmentEntry.JobAdjustmentForm).InvokeMember("baseDockManager", BindingFlags.Instance | BindingFlags.GetField | BindingFlags.NonPublic, null, JobAdjustmentForm, null);
dock = (Infragistics.Win.UltraWinDock.UltraDockManager)obj;
dock.DockAreas[0].Panes[0].Closed = true;
tbJobNum = (Ice.Lib.Framework.EpiTextBox)csm.GetNativeControlReference("3641fc21-c767-4d05-ad24-e203b81d5c9d");
cboAsmSeq = (Erp.UI.Controls.Combos.JobAsmSearchCombo)csm.GetNativeControlReference("14a7d417-59c4-4aa3-876d-e3b5b508ee2b");
cboOper = (Erp.UI.Controls.Combos.JobOperSearchCombo)csm.GetNativeControlReference("edfe956b-51d3-4100-b04a-bf09c63d7219");
tbEmployeeNum = (Ice.Lib.Framework.EpiTextBox)csm.GetNativeControlReference("8a264b4b-1119-46b1-9491-226529cb9b13");
neLaborQty = (Ice.Lib.Framework.EpiNumericEditor)csm.GetNativeControlReference("26255153-54c1-4fe1-a4f2-97f9d4c4c72c");
neLaborHrs = (Ice.Lib.Framework.EpiNumericEditor)csm.GetNativeControlReference("d88e956d-66bb-4274-a99d-4a2a807ac705");
neBurdenHrs = (Ice.Lib.Framework.EpiNumericEditor)csm.GetNativeControlReference("fc8dfa3e-e125-4fa2-b931-80f431559982");
neLaborCost = (Ice.Lib.Framework.EpiNumericEditor)csm.GetNativeControlReference("1fce4c41-2091-4b18-88ae-0f1f959d79a4");
neBurdenCost = (Ice.Lib.Framework.EpiNumericEditor)csm.GetNativeControlReference("fa2d6fe9-5c6a-4d59-a176-8e3b6d268c66");
this.epiButtonC1.Click += new System.EventHandler(this.epiButtonC1_Click);
this.btncosts.Click += new System.EventHandler(this.btncosts_Click);
this.btncopy.Click += new System.EventHandler(this.btncopy_Click);
ugupdatelist();
this.epiButtonC1.Click -= new System.EventHandler(this.epiButtonC1_Click);
this.btncosts.Click -= new System.EventHandler(this.btncosts_Click);
this.btncopy.Click -= new System.EventHandler(this.btncopy_Click);
// Begin Custom Code Disposal
// End Custom Code Disposal
private void epiButtonC1_Click(object sender, System.EventArgs args)
ugupdatelist();
private void btncosts_Click(object sender, System.EventArgs args)
ugupdatecosts();
private void btncopy_Click(object sender, System.EventArgs args)
ugupdatecosts();
tbEmployeeNum.Text = "jdack";
neLaborHrs.Value = ugcosts.Rows[0].Cells["Lab_Bur_Hrs"].Value;
neBurdenHrs.Value = ugcosts.Rows[0].Cells["Lab_Bur_Hrs"].Value;
neLaborCost.Value = ugcosts.Rows[0].Cells["Lab_Cost"].Value;
neBurdenCost.Value = ugcosts.Rows[0].Cells["Bur_Cost"].Value;
Appreciate any help, hints or tips! Thank you!
