Updateable dashboard embedded in customer entry
I am wondering if there is a way to embed an updateable dashboard to a standard entry? I assume that it will only work with runtime dashboards?
Good question…
P.S. I just did a VERY simple test of sheet wizard/appbuilder/menuID and adding the updateable dashboard on an entry form did work. Only without publish/subscibe at this point but, looked promising.
per thread below…maybe
“All you need to do is create a menu item for your deployed updatable dashboard, then in sheet wizard add the menu item. Voila - embedded updatable dashboard”.
Found it myself, it is just the matter of attaching the compiled version of the dashboard. There is a choice when attaching the dashboard as a runtime or compiled version.
Updatable dashboard only work as deployed out as Dashboard Assemblies. So you need to add it in Menu Maintenance as a dashboard assembly. Log out and back in then use the customization sheet wizard to add it as a ‘AppBuilder Panel’ using the MenuID you created in Menu Maintenance.
Thanks sir, working as a charm.
Anyone know if you can embed a dashboard with a customization?
I have this same question. I am working through a project, and need to use the embedded dashboard functionality. But I don’t see a way to pull the customization from the deployed dashboard into the embedded dashboard.
Are you able to use the Embedded Dashboard with a Customization?
