Just curious, has anyone found any simple magic to allow you to:
- create an Updatable Dashboard that allows ADDING new records
- BUT when EDITING an existing row, certain fields would become Read ONLY
If so: how did you do it?
I think if you make the fields in the extended properties (the master one, not on the form) when you make a new row it’s editable, and then when you save, it become read only. It was doing that to me by accident when I was trying to make a grid in a UD customized field be read only all of the time. I had to use the customization wizard to make the field read only on the form all of the time. I haven’t tried it in a dashboard though.
Maybe worth a shot?
I got around my particular issue by adding BAQ/BPMs that checked for changes to the fields if it was not an add. Then I throw an error if they try to change.
