Then at that point I think you have to make the adjustment to the
job....whenever you create changes it does ask for an employee to make
the change against anyway.
HTH,
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
Of Tony Hughes
Sent: Tuesday, August 12, 2008 8:11 AM
Subject: Re: [Vantage] Updating labor transaction on a Posted labor
entry
We don't license the Payroll module, and so when the company
configuration was set up, probably the "Labor to Payroll" check box was
checked or left checked by default without thought to what it meant.
What it does is "process" payroll each night, and that leaves each
laborhed entry as marked as Posted and therefore not able to be changed.
This "processing" is meaningless without the Payroll module, other than
it leaves you unable to modify the labor entry through normal means,
i.e. Labor Entry.
I've corrected this going forward (I think) but there are labor
transactions that need to be edited and can't be because system thinks
they are posted.
So, question is, how do I correct "posted" labor transactions?
Do I edit them, or post some negative against it or what...
----- Original Message ----
From: Manasa Reddy <manasa@... <mailto:manasa%40weldcoa.com> >
Sent: Monday, August 11, 2008 3:47:19 PM
Subject: RE: [Vantage] Updating labor transaction on a Posted labor
entry
Where are you seeing the POSTED marker?
Usually you would go into job adjustments to update a job or go into
Labor Entry and just add another entry.
M. Manasa Reddy
manasa@weldcoa. com
P: 630-806-2000
F: 630-806-2001
____________ _________ _________ __
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On
Behalf
Of Tony Hughes
Sent: Monday, August 11, 2008 2:59 PM
To: vantage@yahoogroups .com
Subject: [Vantage] Updating labor transaction on a Posted labor entry
How do you update/modify a labor transaction on an employee when the
POSTED marker is indicated?
HTH,
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
Of Tony Hughes
entry
i.e. Labor Entry.
they are posted.
entry
M. Manasa Reddy
manasa@weldcoa. com
P: 630-806-2000
F: 630-806-2001
Behalf
Of Tony Hughes
