You would run these commands on the client workstations, not the server.
Greg Bakker
Kooima Company
Greg Bakker
Kooima Company
--- In vantage@yahoogroups.com, Greg Payne <gpayne@...> wrote:
> We had this kind of issue and the cause was the programdata directory permissions.
> The commands below will clear all old Epicor cached info. If they fail, then a network admin will need to run them.
> Greg
> rem Windows 7
> rd /S /Q c:\ProgramData\Epicor
> rem Windows XP
> rd /S /Q "c:\Documents and Settings\All Users\Application Data\Epicor"
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Mark
> Sent: Monday, May 13, 2013 8:46 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Updating/Resaving Customization problems
> Make sure to select PO Entry from the Main Menu and not from the Favorites Menu.
> Thanks,
> Mark
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "lisassar" <lisa.saren@<mailto:lisa.saren@>> wrote:
> > But the new changes doesn't show and the customization isn't "live" without developer mode.. What could be the problem here?
> > Kind regards,
> > Lisa
> > --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Karen Schoenung <kschoenung@> wrote:
> > > Ver 8.03.409<tel:803409>c
> > > No
> > > Customization will be live when you log out and back in
> > > Connected by DROID on Verizon Wireless
> > > -----Original message-----
> > > From: lisassar <lisa.saren@>
> > > To: "vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>" <vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>>
> > > Sent: Mon, May 13, 2013 08:32:55 GMT+00:00
> > > Subject: [Vantage] Updating/Resaving Customization problems
> > > Hi everybody!
> > > We are having problems with our customizations. We choose a customization to be standard (Via Menu Maintenance) on for example the PO Entry.. and then if we make a change on that customization and save the customization, the new changes doesn't show and the customization isn't running at all if we clear the client cache. Even if we clear it as the default under the Menu Maintenance, and then save it again, it doesn't work properly. Do we have to "save as" a new customization for each time we want to make a small change?
> > > Kind regards,
> > > Lisa
> CONFIDENTIALITY NOTICE
> The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately delete the communication.
> "This (document/presentation) may contain technical data as defined in the International Traffic In Arms Regulations (ITAR) 22 CFR 120.10. Export of this material is restricted by the Arms Export Control Act (22 U.S.C. 2751 et seq.) and may not be exported to foreign persons without prior approval form the U.S. Department of State."
