Can I upgrade from 2023.2.36 to 2025.2.11? or should I upgrade my prod to 2023.2.41 then on another server install 2025.2.11 and upgrade the prod dbase backup to 2025.2.11? thanks,
Use the upgrade guides on EpicWeb but I think you’ll have to go from 2023 to 2024 then to 2025.
When you upgrade to a new version, all the data migrations for each major release in between your current and target versions will be run.
In your case, the upgrade will run the data migrations for versions 2024.1, 2024.2, 2025.1 and 2025.2.
Thanks much for the info guys, greatly appreciate your insight.
