Thanks, Mark, and Kersten -
I had thought of un-releasing the job, but that would require an
Engineer, not an Inspector, which just adds more confusion (at least,
for our people). Mark's idea to change First Article requirements is
similar to an idea we had, but we'd actually thought of clocking one of
the inspectors in to the operation as "Beginning Setup," which we think
has the desired effect of locking the operation without necessitating
going into the job, un-releasing/un-engineering the part, etc...
Does clocking the Inspector into the operation as "Begin Setup" lock the
process, or only if there are outstanding first-article requirements?
And, when he clocks out of the Setup, will it automatically create a
piece that needs to be inspected and place a line in the Inspection
Processing panel?
Thanks again!
--Ari
Of Mark Wagner
Sent: Tuesday, July 15, 2008 10:22 AM
Subject: RE: [Vantage] v6.1 Quality Freezing Production
One option would be to set a first article quantity for that job
operation. Once a first article quantity is set, the operator can not do
anything on the operation until the first article quantity has been
approved
--- On Tue, 7/15/08, Kersten MacLennan <kmaclennan@...
Date: Tuesday, July 15, 2008, 10:59 AM
I have had the same question. The only easy answer I came up with is to
unrelease the job.
Kersten MacLennan
IT/ERP Analyst
Semrock, Inc.
3625 Buffalo Rd.,
Suite 6
Rochester, NY 14624
585-594-7009
585-594-7095 fax
kmaclennan@semrock. com
The Standard in Optical Filters for Biotech & Analytical Instrumentation
Hundreds of Thousands of Ion Beam Sputtered filters delivered -
extensive inventory now!
The information contained in this message and any attachments may be
privileged, confidential, and protected from disclosure. If the reader
of this message is not the intended recipient, or any agent responsible
for delivering this message to the intended recipient, you are hereby
notified that any dissemination, distribution, or copying of this
communication may be unlawful and therefore strictly prohibited. If you
received this message in error, please reply to the message and delete
it. Thank you
____________ _________ _________ __
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On
Behalf
Of Ari Footlik
Sent: Tuesday, July 15, 2008 10:42 AM
To: vantage@yahoogroups .com
Subject: [Vantage] v6.1 Quality Freezing Production
Is there a feature in Vantage whereby a Quality Inspector can take an
action that, in effect, "freezes" the production of a part, disallowing
further work from being done on that part/operation? Say, for example,
quality notices, in the middle of a production run, a problem which
indicates an issue with the machine or process. Is there some flag or
hold that Quality can enable that will prevent machine operators from
being able to clock-in to that part until Quality releases the hold?
Thanks.
--Ari
Processing panel?
Thanks again!
--Ari
Of Mark Wagner
approved
unrelease the job.
Kersten MacLennan
IT/ERP Analyst
Semrock, Inc.
3625 Buffalo Rd.,
Suite 6
Rochester, NY 14624
585-594-7009
585-594-7095 fax
it. Thank you
Behalf
Of Ari Footlik
Thanks.
--Ari
