Vantage 8.03.407 Order Job Wizard
Hi
I presume that you must ship the goods as soon as they are made> or do you book them into the warehouse for later dispatch?
erwin
--- In vantage@yahoogroups.com, Linda Lowney <llowney@...> wrote:
> Hi Erwin,
> No, we are not creating a part.
> Regards,
> Linda
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of erwin
> Sent: Tuesday, December 13, 2011 5:19 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Vantage 8.03.407 Order Job Wizard
> Hi
> Just reading this thread and was wondering, when you create the sales order \ Job, are you also creating a Part? We have a bug that does not populate the Part with the correct mom structure have you experienced this? The job creation routine for us has always taken a few minutes per quote \ Job.
> Erwin
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Linda Lowney <llowney@> wrote:
> > Hi,
> > I know it used to be pretty fast to create the order and jobs from the quote and I don't know how long it has been since it slowed down. Nobody complained until recently; they just worked around it.
> > Regards,
> > Linda
> > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of cooner_55421
> > Sent: Monday, December 12, 2011 4:44 PM
> > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>
> > > I'm sorry, I guess I wasn't very clear.
> > No problem.
> > Like I said, I've had to check out quotes lately anyway.
> > So this wasn't too far to stray.
> > >5 minutes to create a bunch of blank jobs.
> > That does seem excessive.
> > FYI... I just did a simple quote with 10 lines on a backup test system. Only added methods on the last line.
> > -- only took a few seconds to create all the jobs.
> > This time I pulled methods for the last line & that worked.
> > --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, Linda Lowney <llowney@> wrote:
> > > Hi,
> > > I'm sorry, I guess I wasn't very clear. Nine of the ten jobs did not have any operations or materials in the quote so I don't expect them to have operations or materials in the job. We just wanted the jobs created. Sometimes we put the job info in the quote and other times we wait until the job is created to add the operations and materials. Thank you for checking it out though.
> > > I'm just wondering why it takes 5 minutes to create a bunch of blank jobs.
> > > Regards,
> > > Linda
> > > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of cooner_55421
> > > Sent: Monday, December 12, 2011 3:31 PM
> > > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> > > Hi Linda,
> > > >It created 10 jobs, 9 of
> > > >which were empty and one that had one operation.
> > > Just now I built a simple quote on a test system.
> > > 1 line with 2 operations and 2 materials, then used the Job Wizard. (V8.03.409C).
> > > The Job was missing the operations.
> > > Later I pulled the details from that quote into Job Entry directly.
> > > I was just curious. I don't normally build methods in the quote so maybe the error is due to the way I processed this.
> > > I did have to test quotes for errors recently.
> > > I saw data dropped in the case of certain entry sequences.
> > > So now we're in the habit of checking any Sales Orders generated from quotes.
> > > --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, Linda Lowney <llowney@> wrote:
> > > > Hi Group,
> > > > It takes about 5 minutes to create orders and jobs from quote entry. I turned on trace logging then ran the order/job wizard. It took 0:14 minutes to create the order, 1:01 to run the OrderJobWiz GetMatrix method, 1:08 to run the OrderJobWiz SelectAll method, 0:02 to run the OrderJobWiz ValidateJobs method and 2:34 to run the OrderJobWiz CreateJobs method. It created 10 jobs, 9 of which were empty and one that had one operation.
> > > > Does anyone have any idea why this might be happening? There are no BPMs running on the OrderJobWiz.
> > > > Regards,
> > > > Linda
> > > > [Non-text portions of this message have been removed]
Hi Group,
Regards,
Linda
Hi Linda,
> Hi Group,
> Regards,
> Linda
Hi,
Regards,
Linda
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of cooner_55421
Hi Linda,
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Linda Lowney <llowney@...> wrote:
> Hi Group,
> Regards,
> Linda
No problem.
> Hi,
> Regards,
> Linda
> Hi Linda,
> > Hi Group,
> > Regards,
> > Linda
Hi,
Regards,
Linda
No problem.
> Hi,
> Regards,
> Linda
> Hi Linda,
> > Hi Group,
> > Regards,
> > Linda
Hi
Erwin
> Hi,
> Regards,
> Linda
> No problem.
> > Hi,
> > Regards,
> > Linda
> > Hi Linda,
> > > Hi Group,
> > > Regards,
> > > Linda
Hi Erwin,
Regards,
Linda
Hi
Erwin
> Hi,
> Regards,
> Linda
> No problem.
> > Hi,
> > Regards,
> > Linda
> > Hi Linda,
> > > Hi Group,
> > > Regards,
> > > Linda
