Vantage Performance tuning
Raid5 will kill the speed of any database, write speeds on raid5 are too slow. We run Vantage on a server with the system partition setup as a mirrored set, database and vantage app files located on a raid10 array. using a higher number of drives in a raid10 array will increase performance. our system runs great
--- In vantage@yahoogroups.com, "randyduly" <randy.duly@...> wrote:
> Hi -
> You mentioned RAID-5 at the beginning of your email. Everything I read said don't use RAID-5 because of performance issues. Use RAID-10 instead. Are you using RAID-5 anywhere?
> --- In vantage@yahoogroups.com, "mseal" <mseal@> wrote:
> > Over the last month we have been working on optimizing Vantage in every way possible.
> > Wanted to share with all our findings and hear from others if there are any other suggestions.
> > Would be nice if Epicor continued to test and publish all aspects related to performance tuning as many of us complain about the issue but don't receive much help.
> > First our environment:
> > Vantage 803.404B – over 80 regular + MES licenses
> > MS-SQL dB (2005)
> > VMWare (ESX 4.0)
> > Cluster of Dell servers (1950) with 2 X Quad core and plenty of memory
> > EMC SAN configuration has 3 storage levels – RAID-10 RAID5 on 15K SAS and RAID5 on SATA drives with 3 full shelves of drives to spread drive/spindle load.
> > Epicor application server on Windows 2003 Enterprise with 8Gb
> > SQL on 2003 STD addition
> > In general we were not happy with system performance starting with Print Preview to night processes (MRP/PO Gen ..) to regular transactions.
> > We evaluated client, server and systems to come up with best possible performance.
> > After applying all changes we have realized a cut in the time to perform different processes and transactions form 25% to over 80%
> > Here are the area we reviewed and the we found helpful – I have marked (*) the ones most beneficial
> > Client Computers:
> > 1 – ensure AV does not scan Client folder
> > 2 – change system monitor settings – this may increase print preview performance by 50%
> > 3 – set all users to `can suspend' - help eliminate client disconnects
> > 4 – set all NICs to no power off - help eliminate client disconnects
> > 5 – min memory – 2Gb
> > 6 – difrag HD
> > SQL server:
> > 1 – move tempdb to RAID10
> > 2 – don't scan MDF & LDF files (SQL)
> > 3 – consider RAW device mapping (VMWare)
> > 4 – move SQL to 64-bit server and OS to 64-bit ***
> > 5 – move server to latest CPU ***
> > 6 – verify SQL index optimization
> > Application server:
> > 1 - Setup with separate print server **
> > 2 - Upgrade to 803.409
> > 4 –Move app server on 64-bit *
> > Chipset tested Xeon X5355 2.66Ghz and Xeon X5570 2.9Ghz
> > If you want to know anything else regarding this study please post here
> > Thanks
> > Motty
MS-SQL dB (2005)
VMWare (ESX 4.0)
Client Computers:
6 – difrag HD
SQL server:
Application server:
Motty
Hi -
> MS-SQL dB (2005)
> VMWare (ESX 4.0)
> Client Computers:
> 6 – difrag HD
> SQL server:
> Application server:
> Thanks
> Motty
RAID 5 is a lot different on a SAN than server. We use RAID 6 across 14 spindles on our NetApp FAS 270. We have NAS, VMware and a RAW drive for SQL on the SAN. We went from RAID 10 on our SQL server to the RAW drive on the SAN and the improvement in speed was overwhelming.
Joe Luster
Network Administrator
Cold Jet, LLC
455 Wards Corner Road
Loveland, Ohio 45140
USA
+1 513-831-3211 x308 (office)
+1 513-831-1209 (fax)
www.coldjet.com<http://www.coldjet.com>
[cid:image001.jpg@01CAC101.C79DB510]
Setting industry standards in dry ice technology and solutions for over 20 years.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of randyduly
Sent: Thursday, March 11, 2010 9:28 AM
Subject: [Vantage] Re: Vantage Performance tuning
Hi -
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "mseal" <mseal@...> wrote:
> Vantage 803.404B - over 80 regular + MES licenses
> MS-SQL dB (2005)
> VMWare (ESX 4.0)
> EMC SAN configuration has 3 storage levels - RAID-10 RAID5 on 15K SAS and RAID5 on SATA drives with 3 full shelves of drives to spread drive/spindle load.
> Here are the area we reviewed and the we found helpful - I have marked (*) the ones most beneficial
> Client Computers:
> 1 - ensure AV does not scan Client folder
> 2 - change system monitor settings - this may increase print preview performance by 50%
> 3 - set all users to `can suspend' - help eliminate client disconnects
> 4 - set all NICs to no power off - help eliminate client disconnects
> 5 - min memory - 2Gb
> 6 - difrag HD
> SQL server:
> 1 - move tempdb to RAID10
> 2 - don't scan MDF & LDF files (SQL)
> 3 - consider RAW device mapping (VMWare)
> 4 - move SQL to 64-bit server and OS to 64-bit ***
> 5 - move server to latest CPU ***
> 6 - verify SQL index optimization
> Application server:
> 4 -Move app server on 64-bit *
> Thanks
> Motty
Motty - which system monitor values and what values did you found most
helpful?
Where those changes made via the system monitor configuration in the system
monitor or in the .mfgsys file on the client system?
Dale Dalton
_____
mseal
Sent: Wednesday, March 10, 2010 7:25 PM
Subject: [Vantage] Vantage Performance tuning
possible.
other suggestions.
much help.
MS-SQL dB (2005)
VMWare (ESX 4.0)
load.
performance.
Client Computers:
performance by 50%
6 - difrag HD
SQL server:
Application server:
Motty
You can make changes in either place – if you use the system monitor it will update the .mfgsys file and a restart of Vantage will bring values to current session
We had the original Vantage default values of 30,000/ 3,000 / 15,000 changed to 120,000 / 3,000 / 60,000
> helpful?
> Dale Dalton
> _____
> mseal
> possible.
> other suggestions.
> much help.
> MS-SQL dB (2005)
> VMWare (ESX 4.0)
> load.
> performance.
> Client Computers:
> performance by 50%
> 6 - difrag HD
> SQL server:
> Application server:
> Thanks
> Motty
"RAID 5 is a lot different on a SAN than server"
How do you figure? The algorithm is essentialy the same spindle for spindle regardless of connection (SAN or DAS).
Randy, for database applications (where IOPS is the name of the game) it's tough to beat RAID10, although you pay the 50% capacity penalty, but it's worth it in my opinion. Disks are relatively cheap.
What you've read is essentially correct. RAID5 is dead in the age of terabyte plus capacity hard drives. RAID5 can only tolerate a single spindle failure, meaning it's vulnerable while it's in the rebuilding state. A hot-spare doesn't really help here since the array will still have to rebuild. And with present day large capacity drives, the chances of another drive encountering an Unrecoverable Read Error (URE) during the rebuild process is high. This will trash the array and you're now restoring from backup. Chances of UREs are decreased with smaller enterprise class disks, but the risk is still there.
RAID6 is better, but still has the same potential, although that would require two disk failures + URE during rebuild to trash the array. Also, I wouldn't implement RAID6 with anything less than 9 spindles.
Jared
> Joe Luster
> Cold Jet, LLC
> USA
> [cid:image001.jpg@...]
> Hi -
Joe,
I was wondering about your comment on Raw Device Mapping on VMWare.
From all the benchmarks I see on VM Ware's site, can see a significant difference in SQL performance. Have you tested it and is it really that much faster?
Also, what type of RDM are you using? Compatible with snapshots?
Motty
> Jared
> > Joe Luster
> > Cold Jet, LLC
> > USA
> > [cid:image001.jpg@]
> > Hi -
