This error can be fixed with a registry change, I actually added
workaround2 and workaround3 for each of the new values.
Add a New String Value to the following Registry Keys
\\HKEY_CURRENT_USER\Software\ODBC\ODBC.INI\(YOUR_DSN_NAME)
\\HKEY_LOCAL_MACHINE\Software\ODBC\ODBC.INI\(YOUR_DSN_NAME)
New String Name = WorkArounds2
Value = 40960
OR
Value = 8192
Value = 40960
OR
Value = 8192
> From: Joanne Yargeau <jyargeau@...>ODBC
> Subject: [Vantage] Version 803 403D ODBC and Access
> To: vantage@yahoogroups.com
> Date: Monday, June 9, 2008, 2:50 PM
> We are on a test server using 803 403D. I have previously used ODBC
> and Access for all of our reporting and reports. In testing the
> drivers in Access on 803, the tables are visible but when I try to7748).
> click on a table I get the following error: 'Reserved error (-
> There is no message for this error.' Can anyone help with what thiscomplex
> error might be? Epicor says they don't support Access because they
> want you to use Crystal Reports. Our Access reports are very
> and have many table joins so it would not be possible to use BAQ'sand
> I don't know Cyrstal other than moving a field here or there and Imay
> think they would be too complex for even Crystal. Is anyone using
> Access and ODBC in 803? I would appreciate any help that someone
> be willing to offer. TIA.
