Jasper,
You are going to have trouble because you will not have "active"
transactions entering them manually.
You might want to do the same type of thing, but use the payroll date from
the labor detail and make it "today" or today-1 or something similar. This
should help you get to a query that shows the labor, and therefore the job
at each machine.
Good luck,
Aaron Hoyt
Vantage Plastics
Sent: Friday, October 29, 2004 9:07 AM
Subject: RE: [Vantage] Wip report
THANK YOU!!
Jasper
Sent: Friday, October 29, 2004 9:02 AM
Jasper,
Here is a copy of my query to show what's clocked in on setup on the shop
floor, first it was done with the wizard.
Next I basically added report builder type fitter items to each join area
Example "and LaborDetail.ActiveTrans = yes" etc....
Notice to I created Outer-joins - I did this so I could use this script for
Setup, Production or Indirect Labor. I just cut copied and pasted this in
the separate queries for each.
Also notice I changed the "EACH JobOper" to "First JobOper" to speed up
outer joins where I just wanted the first record. This is a little
performance tip I guess.
Also notice I created the EmpBasic join to display employee names which the
wizard does not do.
for each LaborDtl Where LaborDtl.Company = cur-comp
and LaborDtl.ActiveTrans = yes
and LaborDtl.LaborType = "S" no-lock,
First LaborHed Where LaborHed.Company = LaborDtl.Company
and LaborHed.LaborHedSeq = LaborDtl.LaborHedSeq no-lock,
First EmpBasic Where LaborHed.Company = EmpBasic.Company
and LaborHed.EmployeeNum = EmpBasic.EmpID,
First JobOper outer-join no-lock Where JobOper.Company = LaborDtl.Company
and JobOper.JobNum = LaborDtl.JobNum
and JobOper.AssemblySeq = LaborDtl.AssemblySeq
and JobOper.OprSeq = LaborDtl.OprSeq,
First JobHead Outer-join no-lock Where JobHead.Company = LaborDtl.Company
and JobHead.JobNum = LaborDtl.JobNum
BY LaborHed.PayrollDate
BY LaborDtl.WCCode:
Patrick Winter
sSc Specialty Screw Corporation
Vantage 6.10.514, Progress 9.1D08, Windows 2003 Server, Crystal 8.5.3.975
Sent: Friday, October 29, 2004 7:49 AM
We are on 5.2 and are not using data collection. We're still entering the
times sheets daily. How would you make it into a dashboard query in 6.1?
This would be most helpful even though there is a time lag between when the
job is done and when they enter in the time cards. Eventually, we will
start using data collection. Hopefully by the end of the year! How would
you make the query?
Jasper
Sent: Friday, October 29, 2004 8:38 AM
Jasper,
What version of vantage are you on and are you using data collection. This
makes for a great dashboard query.
Patrick Winter
Sent: Thursday, October 28, 2004 2:47 PM
To: Vantage Groups (E-mail)
Subject: [Vantage] Wip report
How would I create a report that could tell me on a daily basis what job is
running at each machine?
Any Ideas?
Jasper
------------------------ Yahoo! Groups Sponsor --------------------~--> Make
a clean sweep of pop-up ads. Yahoo! Companion Toolbar.
Now with Pop-Up Blocker. Get it for free!
http://us.click.yahoo.com/L5YrjA/eSIIAA/yQLSAA/PhFolB/TM
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
at each machine.
Good luck,
Aaron Hoyt
Vantage Plastics
THANK YOU!!
Jasper
Jasper,
wizard does not do.
BY LaborDtl.WCCode:
Patrick Winter
you make the query?
Jasper
Jasper,
Patrick Winter
Any Ideas?
Jasper
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
