Thanks Troy. I'll give this a shot.- Les
> -----Original Message-----
> From: Troy Funte [SMTP:tfunte@...]
> Sent: Wednesday, January 02, 2002 1:05 PM
> To: vantage@yahoogroups.com
> Subject: Re: [Vantage] 5.1 explorer tool
> Les,
> If you have the Progress Adminservice for 9.1A installed, then Progress
> Adminservice for 9.1C won't work. Go in to your services on the NT server
> and "disable" the 9.1A (even if it is already stopped, you need to disable
> it). Then reboot the server. 9.1A and 9.1C don't like being installed on
> the same machine.
> Troy Funte
> Liberty Electronics
> From: Les Tingley
> Sent: Wednesday, January 02, 2002 1:02 PM
> Subject: RE: [Vantage] 5.1 explorer tool
> Thanks Wendy. I'm still on NT. I'm also getting "The server or the
> system
> has no more Resources. Try a larger -n (748) Do you know if this can be
> done
> in 5.1 without going through the Explorer tool? Seems like everything is
> done through it.
> Thanks - Les
> > From: Wendy Bowen (Pursche) [SMTP:wpursche@...]
> > Sent: Wednesday, January 02, 2002 12:50 PM
> > Les,
> > I had a similar situation when I converted us to 5.0. Our vantage
> server
> > is W2K and apparently the Explorer tool can have a slight glitch when
> > installing it to a W2K server. I received a "snap-in" error when I
> tried
> > to implement the tool. But, just like you, my Admin service started
> > anyway and I didn't have any problems otherwise.
> > I did end up calling tech support about 4 months later to fix the
> error.
> > I ended up reinstalling just Progress.
> > Wendy Bowen
> > Network Administrator
> > Schmald Tool & Die, Inc.
> > (810) 743-1600 ext.323
> > wpursche@...
> > From: lptingley
> > Sent: Wednesday, January 02, 2002 12:44 PM
> > Subject: [Vantage] 5.1 explorer tool
> > I did the 3.0 to 5.1 conversion last week, and we went live this
> > morning. No show stoppers, but my Progress Explorer Tool won't work.
> > I get an error message suggesting it isn't a Microsoft Management
> > Console Document. 5.1 Admin Service is started. Is this a quick fix
> > or should I call support?
> > Thanks,
> > Les Tingley
> > MIS
> > Decorated Products
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> > have already linked your email address to a yahoo id to enable access.
> > (1) To access the Files Section of our Yahoo!Group for Report Builder
> and
> > Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.
> > http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/links
> > Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
> have already linked your email address to a yahoo id to enable access. )
> and Crystal Reports and other 'goodies', please goto:
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
