Progress Explorer Tool
Have you used the progress explorer tool on a Windows 2000 Pro workstation
sometime since the last time you used it on the NT4 machine? I had an issue
similar to this when we upgraded to 5.1 - tech support helped me resolve it,
and I was CRAZED at the time, so my notes are pretty sketchy. It is
something about opening the explorer tool on a W2K machine. This should be
on eranet or whatever they're calling it right now-or Ben or David at
support should be able to help.
Lydia
Sent: Wednesday, June 26, 2002 7:37 AM
Subject: [Vantage] Re: Progress Explorer Tool
--- In vantage@y..., Wayne Cox <wmc20@x> wrote:
> At 12:55 PM 6/26/2002 +0000, you wrote:
> >Has anybody had the problem when they go into the progress
explorer
> >tool they get the following message on the server.
> >"The selected file is not a microsoft management console document"
> Which OS and version of MMC are you running? You might try
downloading an
> updated MMC from micros$$t (1.2 or higher).
> -Wayne Cox
> Twenty Three -- Information Technology Consulting
> 828-685-2338
the MMC version is 5.0.1920.2 running on NT4 sp6. The weird thing
is nothing has been installed or updated on the server since the
last time we had to use it (and it worked fine then). We haven't
had the need to actually use it, apart from serving vantage, since
we last copied the database from live to pilot.
Thanks for your input.
Martin Horton
Has anybody had the problem when they go into the progress explorer
On the clients I get the error message.
"Snap in failed to initialise."
Martin Horton
PRD Holdings Ltd.
Which OS and version of MMC are you running? You might try downloading an
-Wayne Cox
828-685-2338
explorer
downloading an
> -Wayne Cox
> 828-685-2338
Martin Horton
explorer
downloading an
> -Wayne Cox
> 828-685-2338
Martin Horton
We had this problem as well. It has to do with the configuration of MMC not
being compatible with NT. Check article 1708MPS in Epicor's knowledgebase
for how to fix it.
Brian Boyes,
Systems Administrator,
Precision Resource Canada Ltd.
<http://www.precisionresource.com>
<mailto:brianb@...>
> we last copied the database from live to pilot..
Thanks Brian.
I'd just got a response from Epicor on the subject. The document
isn't very clear as to why it happend but we managed to piece
together the puzzle of why. We've recently had an XP Pro PC
installed with Vantage and it seems what the knowledge base article
was talking about was if you install a Win 2k pro or XP client it'll
update the Progress Explorer Tool on the NT server! Fantastic.
Once again thanks for your help.
of MMC not
knowledgebase
> for how to fix it.
> Brian Boyes,
> <mailto:brianb@p...>
thing
haven't
since
