Adding Method Tracker to MES
I added a Method Tracker button to the MES menu, and the issue is that it launches Engineering Workbench. When I looked at the menu item, I saw that the program DLL is for Engineering Workbench. I’ve read a few threads on this site that detail how to run some SQL code to use the BOMTracker form instead. But Method Tracker launches fine from the menu, just not from the MES Menu. Is there anything I have to specify in the customization to force Method Tracker to launch?
Method Tracker is super tricky it requires specialized parameters to get invoked since its a form within a form. This is not trivial to do
Okay, I will hold off on this then. Thanks!
Note: We ended up just showing people that they can open Method Master by right clicking on Part Revision in Part Tracker.
