SteveFossey
(Steve Fossey)
November 18, 2023, 1:32am
64
Watched this with interest because we have a lot of code like this.
I just attended the Toronto roadshow this week, and I know @HLalumiere , and I know all four languages that might have lost something in translation (English, French, Linq and Spanish!).
I must say, Epicor and Epicor employees have become much more transparent about problems and misunderstandings in the last few months. It’s really refreshing. We’re all just making it all up as we go in this business and I think everyone has become a lot more sympathetic and supportive. Thanks to Hugo and Santiago and all of the people on here, I learned thtuff.
jgiese.wci
(Joshua Giese)
November 20, 2023, 1:19pm
66
Post summary/solution
Epic_Santiago:
There’s a pretty good chance that I’m the mysterious “reliable source” so allow me to dispel some confusion.
I reviewed a BPM that was reading an entire table (as confirmed via SQL Profiler) as part of an EF query. I rewrote the query to fix the issue and could now see the where clause in the profiler.
The fact that it was re-written in query syntax instead of method syntax has nothing to do with the fix. Either syntax will compile to the same thing and Epicor is not doing anything nefarious here.
It is possible to write a good query with either syntax and a bad query with either syntax. The bottom line is that the problem was a bad query, not the flavour of syntax.
Method syntax was not discouraged nor blamed as the source of the problem. If I gave that impression (assuming I’m the mystery man) then I’ll take the blame for not being clearer.
Query build syntax
josecgomez:
Here’s the same query written both ways and the equivalent executued SQL (Recorded by SQL profiler)
LINQ Query (Methods):
var query = Db.OrderHed
.Where(orderHed => orderHed.ReadyToCalc == true && orderHed.EntryPerson=="EPI-METHOD")
.Join(Db.OrderDtl,
orderHed => orderHed.OrderNum,
orderDtl => orderDtl.OrderNum,
(orderHed, orderDtl) => new { orderHed, orderDtl })
.Join(Db.Part,
combined => new { combined.orderDtl.Company, combined.orderDtl.PartNum },
part => new { part.Company, part.PartNum },
(combined, part) => new { combined.orderHed, combined.orderDtl, part })
.Join(Db.Customer,
combined => new { combined.orderHed.Company, combined.orderHed.CustNum },
customer => new { customer.Company, customer.CustNum },
(combined, customer) => new { combined.orderDtl, combined.part, customer })
.GroupBy(x => new { x.part.PartDescription, x.customer.AccountCoordinator_c })
.Select(grouped => new
PartManager = grouped.Key.PartDescription,
AccountCordinator = grouped.Key.AccountCoordinator_c,
OrderDtls = grouped.Select(x => x.orderDtl).ToList()
}).ToList();
Linq Query Syntax:
var query2 = (from orderHed in Db.OrderHed
where orderHed.ReadyToCalc == true && orderHed.EntryPerson=="EPI-LINQ"
join orderDtl in Db.OrderDtl on orderHed.OrderNum equals orderDtl.OrderNum
join part in Db.Part on new { orderDtl.Company, orderDtl.PartNum } equals new { part.Company, part.PartNum }
join customer in Db.Customer on new { orderHed.Company, orderHed.CustNum } equals new { customer.Company, customer.CustNum }
group new { orderDtl, part, customer } by new { part.PartDescription, customer.AccountCoordinator_c } into grouped
select new
}).ToList();
SQL Diff
MethodVsQueryJoinsKinetic2023 - Diffchecker
It literally generated the EXACT SAME SQL Down the the intermediate table names. I purposely chose a mildly complex query with joins where clauses and grouping.
This was in a Pre Processing BPM on ABCode->GetNew()
Epicor object/compiler results
jgiese.wci:
I added these equal queries of each syntax to a BPM
var queryMethodSyntax = Db.Part
.Join(Db.PartRev, part => new { part.Company, part.PartNum }, rev => new { rev.Company, rev.PartNum }, (part, rev) => new { part, rev })
.Where(joined => joined.rev.Approved == true)
.Select(joined => new { joined.part, joined.rev });
var queryRegularSyntax =
from part in Db.Part
join rev in Db.PartRev on new { part.Company, part.PartNum } equals new { rev.Company, rev.PartNum }
where rev.Approved == true
select new { part, rev };
I then decompiled them and the decompiled code out of Ice.CustomizationStore was the same with the exception of one directly queryable the other was an anonymous function delegate. So even at the c# level nothing is managed different in terms of memory. This would indicate no funny business from Epicor.
When I looked into the diffrence between the expression tree vs enumerable it actually sounds like the enumerable would possibly be microseconds slower and one occurs in memory and the other out of memory. That just determines when the query happens though nothing else. one occurs when the statement is written the other occurs when you start a foreach on it. Nothing else that I can find.
