I created a nice BAQ report that summarizes our jobs/capacity by production line. I want to add an optional subreport to display the details… there’s enough other stuff in the summary report that I can’t just let the report do my grouping/summarizing for me… I want to pass that in to the report from Epicor already done. So I created a separate BAQ report (right, wrong, or other) for the details… but I want that to be a subreport in the first BAQ report. Can it be done? If not, what is the correct way to accomplish my goal? I tried adding a BAQ to the BAQ report’s data definition but that doesn’t seem to be the way.
Mr. Dan: I would start with a new RDD and make this an “RDD Report”. You can add as many BAQ’s as you like to that kind of report.
The setup is a little trickier - but far more powerful.
Here is a quick outline
- Add new RDD
- Add BAQ(s) to RDD
- Map Parameters from BAQ
- Add Filters (when applicable)
- Create Report Style
- Make sure to use the RDD you created for the datasource
- From report style Actions–>Create SSRS Report.
- Download the SSRS report. Update report, then upload it.
- Add “Report” to menu (to launch and test report)
- Done - everyone happy
DaveO
That makes a lot of sense! I’ll give that a shot. Thanks @DaveOlender
Go all the way to the bottom of the service list and look for “DynamicCriteriaReport”.
DaveO
Yep. We got it wired up now. I have one additional request. I was planning on setting up an option to show/hide details… the BAQ Report designer made that very easy. Now that I’m in the “dynamic” report, how can I achieve this so I get an option on the Print dialog?
I suppose worst case scenario I can just create a second report style. That’s probably the easiest way to do this.
Mr. Dan: You can add a prompt to the RDD - however i typically will add a Parameter to the BAQ. Either way will work - that way you will not have to add a report style.
DaveO
Thanks again! I got it all working nice and even have a checkbox that a user can check to show/hide details.
Mr. Dan: You are the MAN!
Congrats and welcome to a new part of the Epicor world.
DaveO
