Well, it didn't show up as pretty as when I pasted it into my previous message. Sorry.
On a separate note, there is also a list that has recently been started on Vmug (Vantage/Vista Midwest User Group). You'll need to get a username and password to see it. http://www.vantageusers.org/
For other resources, I posted a list to the Epicor Vista Forum a while back... http://forums.epicor.com/forum_posts.asp?TID=1365&KW=resource&PID=3528#3528
Matt
Matt
--- In vantage@yahoogroups.com, "vistapdmmatt" <mh@...> wrote:
> There is a list maintained by Epicor. You'll need your EpicWeb login to
> view it. I'm not sure how useful the list really is, but it does allow
> you to search for bug and enhancement requests. I've not found it
> completely easy to search. Anyway, here it is...
> https://epicweb.epicor.com/ReportServer/Pages/ReportViewer.aspx?%2fePort\
> al%2fSearchCRs&rs%3aCommand=Render&rc%3aParameters=true&rc%3aToolbar=tru\
> e
> <https://epicweb.epicor.com/ReportServer/Pages/ReportViewer.aspx?%2fePor\
> tal%2fSearchCRs&rs%3aCommand=Render&rc%3aParameters=true&rc%3aToolbar=tr\
> ue>
> Lets see if I can paste a sample in here...OK...here is a list of all
> open High priority change requests for Vantage...wow, it shows items
> open since 2000. if you leave it as an oepne ended search over all
> versions.
> CR Number Description Version Priority Open Date
> Status 5117MPS "Shopwrn in use by XXX" (2624) then (2661) 1
> 03/14/2001 Open 3151ESC JM In Job Closing the Backflush box is not
> updating. 1 11/25/2008 Open 3140ESC JM Error 'Record not
> available' in Job Closing 1 11/24/2008 Open 3136MPS Unable to
> Print Crystal Forms receive errors 1 01/19/2000 Open 3132ESC
> Error 'Unexpected Error' when trying to save a quote. 1 11/21/2008
> Open 3566ESC PM Purchasing suggestions not generating any
> suggestions. 2 02/09/2009 Open 27229MPS IM Retrieved
> transactions disappear when cursor is moved to part field 2
> 01/09/2008 Open 27513MPS ENG Drag and drop allows you to add the
> parent part as a material to itself 2 02/21/2008 Open 24303MPS
> UserFile.ValidatePassword is not avaiable via BPM, why? 2 03/08/2007
> Open 90BRK OM - Mfg cancel suggestion should be created when ... 2
> 01/23/2001 Open 27224MPS JM Production detail report is not printing
> all sub assemblies 2 01/08/2008 Open 12081MPS DELETE ME 2
> 07/13/2004 Open 658SYD Supplier price list the currency is greyed
> out. 2 02/15/2008 Open 1156ESC OM Pricelist Import Process 2
> 12/21/2007 Open 3140MPS PO forms are missing fields (ABLE TO
> DUPLICATE) after loading .610 2 01/19/2000 Open 1157ESC OM Price
> List not functioning correctly 2 12/21/2007 Open 27139MPS PC PO
> tracker does not show the receipt attachments 2 12/26/2007 Open
> 3165ESC PM Two subcontract suggestions create only 1 PO line 2
> 11/26/2008 Open 23257MPS JM labor edit Icon report is displaying
> labor rates 2 12/21/2006 Open 3422ESC JM Unexpected error when
> saving the job. 2 01/16/2009 Open 28032MPS 5/1 REP Table
> relationships are omitted when a Report Data Def is Duplicated 2
> 05/02/2008 Open 4640MPS PC Rules not showing on test rules report
> (remove -q) 3 12/13/2000 Open 1383ESC SR "Charge ID references
> invalid value" when changing amount to MSC charge 3 02/07/2008 Open
> 4570MPS AR - aging performance in customer tracker 3 11/27/2000
> Open
> --- In vantage@yahoogroups.com, "Michael McWilliams" <mmcwilliams22@>
> wrote:
> > I put in a call yesterday just wondering if epicor keeps a list of
> reported bugs at a current patch level. Here is the response:
> > Hello Mike:
> > We really do not publish a "bug list."
> > The closest document to that would probably be the change list that
> > accompanies any service pack or patch. Attached is the install guide
> > and change list for the Vantage 803.407C patch. The change list at the
> > end is cumulative for all patches (A,B,C) at the .407 service pack
> > level.
> > I hope this answers your question.
> _______________________________________________________________________
> > I really think this is something they should consider doing. Sure it
> helps to know what you fixed, but it also helps to know what other
> problems you will be facing. We are all calling and reporting our
> problems to them anyway, & they are recording the version we are on. It
> would save so much time having that extra info ahead of time instead of
> trying to figure out something does not work when another user has
> already reported it.
> > It should not be that difficult for them to do this, & I am sure they
> do internally so why not publish it.
