Bingo! - Thanks
Sent: Thursday, February 15, 2001 8:19 AM
Subject: Re: [Vantage] Citrix installation
I had the exact problem 2 yrs ago when we setup a Metaframe server. Our
problem was that the Citrix server was connecting to the 100Mhz Hub at
full duplex (you can only use full duplex on switches) ... I manually
switched it to half duplex and it worked perfectly. This may not be
your problem, but you might check it out.
Oleg Tumarkin wrote:
Britt Moelling
M&M Manufacturing Co.
Yahoo! Groups Sponsor
<http://rd.yahoo.com/M=176325.1312152.2904070.1252795/D=egroupmail/S=1700007
183:N/A=572117/R=1/*http://domains.yahoo.com>
183:N/A=572117/R=2/*http://domains.yahoo.com>
www. .com
<http://us.adserver.yahoo.com/l?M=176325.1312152.2904070.1252795/D=egroupmai
l/S=1700007183:N/A=572117/rand=766694182>
To unsubscribe from this group, send an email to:
vantage-unsubscribe@egroups.com
> Go to Windows 2000 termenal server, it's a lot less complicated andwww.
> works really fast.
> From: Greg Clauser [SMTP:gclauser@...]
> Sent: Wednesday, February 14, 2001 2:05 PM
> Subject: [Vantage] Citrix installation
> We just installed a Citrix server and exerything went smoothly until
> we
> installes Vantage. I installed per instructions as an Administrator
> thru
> ADD/Remove programs but otherwise the same as any other workstation.
> Everything runs fine except for Vantage. It takes about 4 minutes to
> get to
> a sign in screen and another 2 ot three minutes to get to the main
> menu.
> Support is scratching their heads and sent me some instructions (doc
> 490MPS)
> to install clients over terminal server & metaframe. It looks exactly
> like
> what we did so I called back. Their only response was to install all
> the
> Vantage executables on the Citrix but that doesn't sound right.
> Anybody got
> some advice?
> BTW - Vantage 4.00.904
> - Windows NT 4.0 Terminal Server sp 6
> - Citrix 1.8 feature rel w/sp 2
> - Citrix server is Compaq 370 with 1.0 Gb RAM and two P3 800
> processors
> - NICs are 10/100
> - Vantage Server is also dual processor running NT 4.0 sp 5
Britt Moelling
www. .com
