Crystal files also go there. We have no problems.
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Monday, August 01, 2005 6:28 AM
Subject: RE: [Vantage] Re: Vantage 6.1 on Windows 2003 Terminal Server
I would be careful with that setting, although it works nice and fast,
it can also mess up your Vantage Crystal reports, since they are
manually set to a TEMP dir location. So if you have any custom reports
you might get errors. EX the packing slip report creates DBF files in
the TEMP dir for printing. So vantage will place them in its default
working dir, but Crystal will be looking in c:\mfgwrk61 or c:\vntgwork
or anywhere else you might have set that reports default dir. Since you
can't make separate prints (reports) for Local VNTG and Terminal VNTG,
you might experience some problems. I suggest doing it my way, just to
be on the safe side.
Thomas Wojewoda
IS Manager
Principal Manufacturing Corp.
2800 South 19th Ave
60155 Broadview IL
phone: (708) 865 7500 ext 544
fax: (708) 865 7632
cell: (708) 259 4864
http://www.principalmfg.com
Of Chris Robisch
Sent: Friday, July 29, 2005 1:27 PM
Subject: Re: [Vantage] Re: Vantage 6.1 on Windows 2003 Terminal Server
If you have the following line for the Terminal Server's .mfg file:
tempdirectory=
it'll use the user's local temp directory in their profile, not
disturbing
anyone else's, and the files will be nicely deleted when they log off.
Sent: Friday, July 29, 2005 5:59 AM
I'm using a Citrix Metaframe Server, and have no problems, but like I
told on more person here, if you want it to work faster and more
smoothly, you should edit your MFG files to match the local drive setup
of the Terminal server (actually not doing this in some cases might
render Vantage useless - especially if you are restricting there rights
to access the local C drive):
[MFG Startup]
Executable=V:\PRGS91D\bin\prowin32.exe
Database=V:\mfgsys60\db\MFGSYS
IniFile=V:\mfgsys60\mfgsys.ini
ParameterFile=V:\mfgsys60\db\mfgsys.pf
ConnectOptions=-N TCP -H privan -S 6000 -ld MFGSYS
TempDirectory=m:\vntgwork
StartupProcedure=mainmenu.w
OtherParameters=-rand 2 -q -basekey ini
mfgsys=VN
mfglanguage=enu
mfgtranslator=yes
;MFGODBCpasswd=sysprogress
;MFGODBCUser=sysprogress
;MFGODBCDbse=mfgsys
;MFGODBCServer=Progress91D
[WFClient]
What I mean is set your temp dir to be local to the terminal server.
Also I suggest adding this to you login script or setting it in the
schedule to run at a time that no one is working and logged into the
server (at least the part about the M drives)
copy \\pripdc\netlogon\ifmember.exe c:\winnt
DEL c:\vntgwork\*.* /f /q
DEL m:\vntgwork\*.* /f /q
DEL m:\vntgwork1\*.* /f /q
Since I have 30 users that log on from work and home, I have two temp
dir's and divide the mfg files evenly, so they don't have conflicts
trying to create the same temp file at the same time. Also if you are
running AD, make sure you give the user local modification rights to his
TEMP dir and give everyone rights to delete files from the Terminal
Server directories.
Thomas Wojewoda
IS Manager
2800 South 19th Ave
60155 Broadview IL
fax: (708) 865 7632
Of Cliff Drumeller
Sent: Thursday, July 28, 2005 5:14 PM
4 GB Ram will handle 100 users. Recommend checking out Enterprise
Server. Standard doesn't effectively us above 2GB of Ram even with the
reg hack. It reserves close to 2 Gb for the OS on standard version. I
put 4GB of ram on my Vantage server and the max db I can load into
memory is 1.3 GB.
I would think this would be the recommended way to go to V8. 80% of my
client computers are over 1 Ghz but only the machines in Engineering
have 1 GB of Ram. I've got 120 client computers. The hardware upgrade
for just the clients will keep us from upgrading to V8. I'm waiting to
see how many other people view this as the way to go to V8.
Cliff
Of rocket7247
Sent: Thursday, July 28, 2005 1:49 PM
Subject: [Vantage] Re: Vantage 6.1 on Windows 2003 Terminal Server
We are also thinking about using TS with our upgrade to 6.1 on a new
server. We have over 100 users.
How much is the license cost for client side TS? How much server
memory is required.
--- In vantage@yahoogroups.com, "Cliff Drumeller" <cliff@m...> wrote:
> Peter
> I agree with Mark. I just upgraded my servers from NT 4 to
Win2k3.
> In the process I dumped Citrix for Windows Terminal Services. Yes it
> takes a little locking down. Make a TS users OU and then restrict
it as
> you like. I also put the shortcut to Vantage in the All Users
startup so
> it automatically comes up when they log in. All I've gotten is
praise on
> how much faster it is, Course I went from a 600Mhz server to a 3 Ghz
> server. As Mark said the Epicor instructions are close enough to
make it
> work.
> Cliff Drumeller
Behalf
> Of Mark Smith
> Sent: Wednesday, May 18, 2005 2:03 PM
Server
> I used to use citrix and you have to use terminal server regardless
it
> just that citrix has a "nice presentation". However, I've abandon
> citrix and use only terminal server with server 2003 as in my
opinion it
> is a superior product. Yes, it is true you must "customize" the
> desktop, but this can be accomplished by using Group Policy
Management,
> but I found it very easy to "lock down" the desktop using this
tool. My
> experience has been nothing but positive with Windows Server 2003
TS.
> The instructions provided by Epicor actually aren't too bad and
setting
> up your terminal server should be somewhat painless. I am
upgrading to
> 6.1 from 6.0 this weekend. I'd be happy to answer any other
questions
> you have with regards to this matter.
> Mark Smith
> Director of Information Systems
> Innerpac, Inc
> (p) 708-863-8300
> (f) 708-863-9770
> www.innerpac.com
Behalf
> Of Peter
> Sent: Tuesday, May 17, 2005 4:34 PM
> What do you want to know? We have 2000, 2003 with and without
Citrix
> in use with terminal services. There are a number of good and bad
> things with each. First is your 2003 terminal licensing might cost
> you. In 2000 hosts running 2000 or XP pro did not need a license.
> With 2003 they will need a license. It appears at first they are
> working, but the have only been issued a temporary license which
> expires after 90 days. With out citrix you can have to do a lot of
> policy and connection setting so the end user doesn't realize they
have
> a whole different desktop they are working on.
> If you have specific questions I'll be happy to answer them.
> --- In vantage@yahoogroups.com, "vantagevista" <vantagevista@y...>
> wrote:
> > I am looking to get some help in setting up Vantage 6.1 in a
Windows
> > 2003 Environment using Terminal Services, does annyone have any
> > experience with this.
> > Thanks,
must
> have already linked your email address to a yahoo id to enable
access. )
Builder
> and Crystal Reports and other 'goodies', please goto:
> <http://groups.yahoo.com/group/vantage/files/>
> Yahoo! Groups Links
> * To visit your group on the web, go to:
> * To unsubscribe from this group, send an email to:
> vantage-unsubscribe@yahoogroups.com
> <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service <http://docs.yahoo.com/info/terms/> .
must
access. )
Builder
> Yahoo! Groups Links
YAHOO! GROUPS LINKS
* Visit your group "vantage
<http://groups.yahoo.com/group/vantage> " on the web.
Yahoo! Groups Links
This transmission may contain information that is privileged,
confidential
and/or exempt from disclosure under applicable law. If you are not the
intended recipient, you are hereby notified that any disclosure,
copying,
distribution, or use of the information contained herein (including any
reliance thereon) is STRICTLY PROHIBITED. If you received this
transmission
in error, please immediately contact the sender and destroy the material
in
its entirety, whether in electronic or hard copy format. Thank you.
have
and
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
