Closing Jobs
Once you close a job, the "tie" between COGS and the job is broken from
a G/L perspective. Prior to job closure, jobs costs flow to the
assigned COGS account(s) as determined in the control account setup.
Once a job has been closed, yes, you can reopen a job and
add/remove/adjust costs to make the job itself look as accurate as
possible, however, any cost revisions after the job has been closed goes
to material variance account (as set up in the control accounts) rather
than the pre-determined COGS account(s).
What we "TRY" to do is wait at least a week after a shipment to make
sure all costs are entered/revised. Then as we get closer to month end,
that week wait time shortens a little. Other than entering/adjusting
labor prior to the month-end WIP Capture (labor is locked for the month
once this routine is run), jobs can remain open into the next month
(there is no need to close jobs ASAP, other than to keep your WIP
relatively clean). After the employee who was closing jobs resigned
several years ago, we dropped the ball on closing jobs for several
months. Then when this process got caught up, we incurred a large jump
in our material variance account as "unclean" jobs were closed and their
unallocated costs all hit the material variance at once.
I hope this helps explain the G/L "break" that occurs once a job is
closed!
Thanks!
Rick Ludwig
Of Sherer, Rhonda
Sent: Tuesday, May 10, 2005 3:46 PM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] Re: Closing Jobs
I'm purchasing and that was a rule used from the accounting/controller
side.
I'm not sure of the reasons. We were good rules people when we set up
Big
V. (I slept once or twice since our implementation in 1999.) Also, we
have
a fairly new controller now, so I'm not even sure the answer hasn't
changed
since then. Sorry.
Sent: Tuesday, May 10, 2005 3:40 PM
Subject: [Vantage] Re: Closing Jobs
Can you explain how closing is final? It appears that you can
(un)close a job at any time...
Ben
--- In vantage@yahoogroups.com, "Sherer, Rhonda" <rhonda@r...> wrote:
> We have held the job closing for "a while" to collect the same kind of
> costs. We often have several subcontract operations at the end of the
> process which would have freight to be adjusted to the job. We have
not
> made it a practice to close and reopen the jobs, as we were cautioned
at
> implementation this would not be good. Closing is final, but
Completion can
> be done as soon as it all ships out.
> From: bbelzer42 [mailto:bbelzer@t...]
> Sent: Tuesday, May 10, 2005 2:01 PM
> Thank you all for your responses.
> Ok, so then here is my next question. I need to go back and add
> freight as a material (don't get me started on that one...) thus they
> told me to keep the jobs open until I get the bills back for freight.
> But, could I instead just reopen the job and apply a cost at a later
> time?
> Thanks,
> Ben
> --- In vantage@yahoogroups.com, jeremyrleonard@a... wrote:
> > You could write a script to close jobs as long as you can figure
out a
> > criteria to use to select what jobs to close. I use Winbatch for
> this but many
> > users on here use Ground Control. I like Winbatch alittle better
> because you can
> > compile the scripts into very small executable files. It doesn't
> take to long
> > for a nontechnical person to figure out. Its also very handy for
> > importing/exporting data from Vantage when other methods are less
> viable.
> > Just a thought,
> > Jeremy
must have
Builder and
<http://groups.yahoo.com/group/vantage/files/.> >
<http://groups.yahoo.com/group/vantage/messages> >
<http://groups.yahoo.com/group/vantage/links> >
> _____
> Yahoo! Groups Links
> * To visit your group on the web, go to:
<http://groups.yahoo.com/group/vantage/>
<http://groups.yahoo.com/group/vantage/> >
> * To unsubscribe from this group, send an email to:
> vantage-unsubscribe@yahoogroups.com
> <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service
> <http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/>
have
and
_____
Yahoo! Groups Links
Service
_____
Yahoo! Groups Links
Service <http://docs.yahoo.com/info/terms/> .
Does anybody know a way to close out more than one job at a time?
Jasper
Contact Epicor custom programming, they can fix you up with one based on how
you want to close, by date,by part etc...$$$$
Mike
>From: "Jasper Recto" <jrecto@...>
>Reply-To: vantage@yahoogroups.com
>To: "Vantage Groups (E-mail)" <vantage@yahoogroups.com>
>Subject: [Vantage] Closing Jobs
>Date: Tue, 25 Mar 2003 15:15:09 -0500
>Jasper
_________________________________________________________________
MSN 8 helps eliminate e-mail viruses. Get 2 months FREE*.
http://join.msn.com/?page=features/virus
Is there a batch process for closing jobs? Our CAM has told us that
we should close them once a month, but with 800-1000 jobs per month it
takes half a day to close these one at a time.
Is there a batch process for this? Or is there a better way to handle
the closing of jobs?
Ben
My company is on a smaller scale than yours, but I close jobs on a daily
basis after the final invoicing has been completed. Invoicing is also
done on a daily basis. Hope this helps.
Judith V. Wayne
Accounting
Debron Industrial Electronics Inc
248-588-7220 ext 1220
wayne@...
Sent: Tuesday, May 10, 2005 12:28 PM
Ben
_____
Yahoo! Groups Links
We close jobs as the job is completed and shipped out. This only takes
about ten to twenty minutes at the most when we are doing them on a daily
basis.
Chris Stover
Business Control Engineer
Deaver Industries
205-426-4309 Voice
205-426-4364 Fax
cstover@...
www.deaverind.com
bbelzer42
Sent: Tuesday, May 10, 2005 11:28 AM
Ben
_____
Yahoo! Groups Links
<http://docs.yahoo.com/info/terms/> Service.
None that I have found. I close jobs daily.
Of bbelzer42
Is there a batch process for closing jobs? Our CAM has told us that we
Ben
Yahoo! Groups Links
You could write a script to close jobs as long as you can figure out a
criteria to use to select what jobs to close. I use Winbatch for this but many
users on here use Ground Control. I like Winbatch alittle better because you can
compile the scripts into very small executable files. It doesn't take to long
importing/exporting data from Vantage when other methods are less viable.
Just a thought,
Jeremy
time?
Ben
this but many
because you can
take to long
viable.
> Just a thought,
> Jeremy
process which would have freight to be adjusted to the job. We have not
made it a practice to close and reopen the jobs, as we were cautioned at
implementation this would not be good. Closing is final, but Completion can
time?
Ben
this but many
because you can
take to long
viable.
> Just a thought,
> Jeremy
_____
Yahoo! Groups Links
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
Ben
Completion can
> time?
> Thanks,
> Ben
out a
> this but many
> because you can
> take to long
> viable.
> > Just a thought,
> > Jeremy
must have
Builder and
> _____
> Yahoo! Groups Links
I'm purchasing and that was a rule used from the accounting/controller side.
I'm not sure of the reasons. We were good rules people when we set up Big
V. (I slept once or twice since our implementation in 1999.) Also, we have
a fairly new controller now, so I'm not even sure the answer hasn't changed
since then. Sorry.
Ben
Completion can
> time?
> Thanks,
> Ben
out a
> this but many
> because you can
> take to long
> viable.
> > Just a thought,
> > Jeremy
must have
Builder and
> _____
> Yahoo! Groups Links
> <http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> > .
_____
Yahoo! Groups Links
If you close a job in one fiscal period, then re-open and CHANGE something
in another fiscal period, somewhere, something will hit a variance account,
thus causing a ripple in the smooth pond of accounting's world. This will
also effect the cost of the item. Accounting wants (and rightly so) to have
as little in variance as possible, because the have to, ah, account for it.
Lydia
Sent: Tuesday, May 10, 2005 1:46 PM
since then. Sorry.
Ben
Completion can
> time?
> Thanks,
> Ben
out a
> this but many
> because you can
> take to long
> viable.
> > Just a thought,
> > Jeremy
must have
Builder and
> _____
> Yahoo! Groups Links
_____
Yahoo! Groups Links
Yahoo! Groups Links
When Capture Cost of Sales is run and posted the costs are purged
from closed jobs and JobHead.WIPCleared is set to true. We run CCoS
at the end of the period so that the G/L is accurate for that period.
One thing you can do is put an estimated shipping cost in the job and
accrue it similar to the way burden is accrued to offset mfg costs.
Then fine tune it for minimum variance.
Russ Dover
> Thanks,
> Ben
> of
> the
> have not
> cautioned at
> Completion can
> they
> freight.
> > time?
> > Thanks,
> > Ben
> out a
> > this but many
> > because you can
> > take to long
> > viable.
> > > Just a thought,
> > > Jeremy
> must have
> Builder and
> > _____
> > Yahoo! Groups Links
> Service
> must have already linked your email address to a yahoo id to enable
> access. )
> Yahoo! Groups Links
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
