Configurator Dynamic List BAQ
We are running an upgrade from 10.2.300.12 to Kinetic 2022_2.4
When we run the upgrade our configurator tests fine form the configurator designer screen.
When I add a dynamic list with a BAQ data source, the first combo box will populate.
When I add the second dynamic list with the same BAQ source and try to filter the contents of the list based off of the first selection the list is blank.
If I hard code data into the criteria, then the list will work.
I saw a post back from 2020 where some other users were having this issue and they stated it was fixed, but there was no actual solution.
I have also tried to run a method to refresh the list but the addition or absence of the ud method does not make a difference.
This sounds oddly familiar, from Today
I don’t know if it IS the same issue, but we were at a loss.
@dr_dan
I opened a ticket with Epicor as well. I will keep you posted if I hear anything.
