Database not created in Epicor 9 Installation
> I have started the appservers and the databases in Progress Explorer tool,
> still it is not working
> Is there any service file or patch file required?
The most recent service pack is 502 and patch B (502B) and you can get it on
EpicWeb.
Mark W.
Hi,
Â
We have installed Epicor 9 in our machine having OS (Windows 2003 Server-Standard Edition) and Sql server 2005.
After Installation we found that Sql doesn't create Epicor databases.
But Open Edge Progress is working fine.
Immediate solution would be highly appreciated.
Â
Thank you & Regards,
Deepa M
Did it not create, or did it not attach the databases?
This happened many times for me with an installation with all versions of 8.00
and 8.03
Deepa
Sent: Sunday, January 11, 2009 5:53 AM
Subject: [Vantage] Database not created in Epicor 9 Installation
Hi,
Â
Â
Deepa M
Thank you for ur promt reply,
I will give you the details as follows:
After Installation ofEpicor 9.04.500 in Windows Server 2003,
1. we tried to open Epicor 9, it shows error message such as "Unable to connect to appserver".
Â
2. When trying to open Epicor 9 Admin console, It shows again error message as "There is no server for database C:\Epicor\db\training\mfgsyssh.(1423)"
Please refer the attached file for detailed view of Error Message.
Thank You & Regards,
Deepa M
Sent: Monday, January 12, 2009 6:35:23 AM
Subject: RE: [Vantage] Database not created in Epicor 9 Installation
and 8.03
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf Of
Deepa
To: vantage@yahoogroups .com
Hi,
Â
Â
Deepa M
http://groups. yahoo.com/ group/vantage/ files/.
http://groups. yahoo.com/ group/vantage/ messages
http://groups. yahoo.com/ group/vantage/ linksYahoo! Groups Links
Did you start the AppServers and database with the Progress Explorer Tool
first?
Mark W.
IÂ have started the appservers and the databases in Progress Explorer tool, still it is not working
If so will you please send me that exe files.
Regards,
Deepa.M
Sent: Monday, January 12, 2009 3:35:42 PM
> C:\Epicor\db\ training\ mfgsyssh. (1423)"
first?
Mark W.
Deepa,
Are the appservers actually starting? I know it probably says they are started,
but can you right click on them and select "Status" and does it show them
running?
I have not had the opportunity to install or play with Epicor 9 yet, so I am
typing to you slightly blind but I am assuming that the connection structure
follows the same methodology as version 8 with connecting to SQL. If someone has
installed version 9, feel free to correct me if I am wrong.
Did the installation create a 32-bit ODBC Connection?
Did you check to make sure there is a DB Created for SQL? Is there an MfgSys90
in your SQL Management Studio under Databases? If not, look in your default
location for SQL Databases and check to see if there is a physical file called
mfgsys90.mdb and mfgsys90.ldb, if so then you will need to "attach" this DB to
your instance of SQL Server in order for it to work.
Deepa
Sent: Monday, January 12, 2009 7:33 AM
Subject: Re: [Vantage] Database not created in Epicor 9 Installation
it is not working
Regards,
Deepa.M
first?
Mark W.
