This sounds very familiar to a situation we had about two years ago
where one of our employees was clocked into the same day twice at the
same time. After a couple of calls to support sending them our database
and using the endact.r program they sent out the situation still
existed. We eventually cleared the problem by going in through an ODBC
connection and deleting one of the records from the LaborHed table.
If you have not done so already you should take look at the raw data in
the LaborHed and LaborDtl tables to see if there are any orphaned
records.
Chris
Of kapokia
Sent: Friday, January 25, 2008 12:12 PM
Subject: [Vantage] Re: Employee stuck Vantage 6.1
Sorry about the confusion, it is in regard a shop employee stuck in
the data collection.
I've also tried to select this employee on the Vantage server instead
of a client, only to get a "Process: Prowin32.exe Application error".
After that the server would become very unstable forcing me to do a
cold boot.
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Bob
records.
Chris
Of kapokia
cold boot.
>Vantage
> Is this in regard to a shop employee and data collection or a
> >this
> > Vantage session will crash without errors if attempting to view
> > employee's data.Vantage
> > "Endact.r" does not remove it.
> > This problem appeared around the time after we converted from
> > 4. to Vantage 6.
> > We had exempt this employee from login in Vantage untill now.
> > Any help will be appretiated.
> > Thanks
> > Jerry
