Inadvertent price changes on PO's due to Price Breaks
Unfortunately, the 'change' doesn't get captured in the 'change log' when the Price Break table is activated and changes the price on a PO. The only way to discover the problem is to notice the variance when the part is received. This is the problem we are having. How do you find these without going through your file and checking every printed PO and comparing it to the current PO price.
Troy Funte
Liberty Electronics
----- Original Message -----
To: 'vantage@yahoogroups.com'
Sent: Thursday, February 14, 2002 9:26 AM
Subject: RE: [Vantage] Inadvertent price changes on PO's due to Price Breaks
There also has been discussion and a suggested enhancement for PO's to add
revision capability. This could be handled in that area as well.
Another thought if price breaks in adjusting the price, which sounds like a
feature but is interpreted as a bug, is it captured in the PO change log?
Patrick
Sent: Thursday, February 14, 2002 7:47 AM
Subject: Re: [Vantage] Inadvertent price changes on PO's due to Price
Breaks
That would have been my original assumption, and was how it worked in 4.0,
but the current 'enhancement' changed that. A printed PO is a contract, and
how could you change the price unless you print a new PO?
Apparently there are some people who DO want to have the price changed even
after the PO is printed -- at least enough for Epicor to change the
functionality in Vantage.
Troy Funte
Liberty Electronics
Sent: Thursday, February 14, 2002 8:43 AM
Breaks
Another suggestion might be for the system not to change the price from
the
price table after the PO is printed.
Patrick
Sent: Thursday, February 14, 2002 7:17 AM
To: Vantage
Subject: [Vantage] Inadvertent price changes on PO's due to Price Breaks
Craig at Epicor helped write up a suggestion on this issue...
We found that the Price Break tables for a Vendor/Part will change to
price
on a Puchase Order without you knowing it whenever you change the quantity
on a PO Line. This has caused some prices to change on PO's that we
didn't
intend due to the fact that we may have set a price agreed upon by the
Vendor for the order regardless of the quantity purchased. Unless the
Purchaser keeps their eye on the Unit Price when changing quantities and
remembers what it should be, they could inadvertently change the price on
the PO (as well as other releases of that line). We found this week that
this had happened to quite a number of parts in our system. Below is the
enhancement # that Craig wrote up if anyone would care to add their name
to
it.
Incidently, back in 4.0, this feature worked more as we would have liked
it
- meaning that the Price Breaks only had effect when the Order was first
set
up. In 5.0 this changed as described above.
Troy Funte
Liberty Electronics
Please reference call # 768433MPS if you have any additional questions on
this issue.
Here is the enhancement suggestion based on the problem you described...
Page ID 7054MPS
PROBLEM DESCRIPTION:
Price changes any time they add a quantity or update the quantity. This
causes problems if the users are not careful to watch whether the price
has
changed or not. In some cases, a price has been negotiated and should be
fixed, no matter what the quantity is.
SUGGESTION:
Price should not refresh from the price break table when the PO quantity
is
changed. Or, customer's should have the option to 'fix' a price on a PO
so
that no matter what, the price would remain fixed at the original quantity
unless the 'fixed' flag was unchecked.
have
Yahoo! Groups Sponsor
ADVERTISEMENT
ADVERTISEMENT
We found that the Price Break tables for a Vendor/Part will change to price on a Puchase Order without you knowing it whenever you change the quantity on a PO Line. This has caused some prices to change on PO's that we didn't intend due to the fact that we may have set a price agreed upon by the Vendor for the order regardless of the quantity purchased. Unless the Purchaser keeps their eye on the Unit Price when changing quantities and remembers what it should be, they could inadvertently change the price on the PO (as well as other releases of that line). We found this week that this had happened to quite a number of parts in our system. Below is the enhancement # that Craig wrote up if anyone would care to add their name to it.
Incidently, back in 4.0, this feature worked more as we would have liked it - meaning that the Price Breaks only had effect when the Order was first set up. In 5.0 this changed as described above.
Troy Funte
Liberty Electronics
Please reference call # 768433MPS if you have any additional questions on this issue.
Page ID 7054MPS
causes problems if the users are not careful to watch whether the price has
SUGGESTION:
Price should not refresh from the price break table when the PO quantity is
changed. Or, customer's should have the option to 'fix' a price on a PO so
That would have been my original assumption, and was how it worked in 4.0, but the current 'enhancement' changed that. A printed PO is a contract, and how could you change the price unless you print a new PO?
Apparently there are some people who DO want to have the price changed even after the PO is printed -- at least enough for Epicor to change the functionality in Vantage.
Troy Funte
Liberty Electronics
Another suggestion might be for the system not to change the price from the
Patrick
To: Vantage
it.
Troy Funte
Liberty Electronics
this issue.
Page ID 7054MPS
SUGGESTION:
ADVERTISEMENT
