Thanks Lydia,
Steve
Sent: Friday, October 20, 2000 6:26 PM
To: vantage@egroups.com
Subject: RE: [Vantage] Jobs On Hold/Final Operation/Added
Operation
Steve:
This does not just impact the production detail report, it also
impacts the
WIP report, and when the "Final Operation" is completed, it
causes the job
to appear in the jobs completed queue for review by whomever it
is that
reviews them before they are marked complete and closed. When
they are
marked complete and closed, they fall off of the WIP report
(after the
Capture WIP is run), making that report a more accurate tool
for accounting
to calculate whatever it is they calculate...do you see I'm at
the end of
expertise?
Anyone who says that "Final Operation" box is UNIMPORTANT is
mistaken. If
you're really going to use Vantage, uh, eManufacturing, to do
what needs to
be done, this is a vital cog in your wheel.
Sorry if someone else answered already, I've been gone and am
just catching
up.
Lydia
Sent: Thursday, October 19, 2000 8:15 AM
To: 'vantage@egroups.com'
Operation
Wayne,
Thanks for the costing info re: the Production Detail Report.
We're
also just getting into job cost detail. We add a final
operation on
every job which we call Job Closing and it requires an entry
from the
last department supervisor to enter in the final completed
quantity on
each job to make sure we have the accurate and complete number
and the
final "operation complete" taken care of . The traveler also
asks the
supervisor to write comments on how the job went, problems, etc.
All
our completed travelers are reviewed by the QC for problem notes
before
being discarded so we can catch problems in advance of the next
run.
Steve
Sent: Thursday, October 19, 2000 10:52 AM
Subject: [Vantage] Jobs On Hold/Final
Operation/Added
Operation
entry. Does it
it has
is on the
Production Detail Report. It uses the reported qty
complete to
calculate
unit cost and profitability. Lots of our jobs have a
final op
like "final
inspection" or "packaging." The job may be running for
a long
time, and
partially completed before that op is touched, so if the
P.D. is
run, it
sees zero completed. By checking the last "real"
manufacturing
op as
"Final," the P.D. uses the quantity on it for its
calculations.
Mostly a
convenience thing if you keep an eye on costs during the
job's
run. Otherwise, we have to do a job adjustment to bump
up the
qty to get
meaningful numbers from the P.D. report.
I think it lets you identify jobs that were configured
differently from the
part revision's router. Also possibly to spot rework
ops, or
other unusual
added costs? Just speculating on this one, I've just
started
getting into
a lot of detail on job costing.
The online help for both options seems to concur with
this,
though.
-Wayne
-------------------------- eGroups Sponsor
We no longer allow attachments to files. To
access/share Report
Files, please go to the following link:
http://www.egroups.com/files/vantage/
(Note: If this link does not work for you the first
time you
try it, go to www.egroups.com, login and be sure to save your
password,
choose My Groups, choose Vantage, then choose Files. If you
save the
password, the link above will work the next time you try it.)
We no longer allow attachments to files. To access/share Report
Files,
(Note: If this link does not work for you the first time you
try it, go to
www.egroups.com, login and be sure to save your password, choose
My Groups,
choose Vantage, then choose Files. If you save the password,
the link above
try it, go to www.egroups.com, login and be sure to save your password,
choose My Groups, choose Vantage, then choose Files. If you save the
Steve
Operation
Steve:
impacts the
causes the job
is that
they are
(after the
for accounting
the end of
expertise?
mistaken. If
what needs to
just catching
up.
Lydia
Operation
Wayne,
We're
operation on
from the
quantity on
and the
asks the
All
before
run.
Steve
Operation/Added
Operation
>I would like to know what gets affected by not checkingthe
>final operation box on the operation maintenance injob
entry. Does it
>affect the schedule in any form.I don't think it affects scheduling. The one BIG impact
it has
is on the
complete to
calculate
final op
like "final
a long
time, and
P.D. is
run, it
manufacturing
op as
calculations.
Mostly a
job's
up the
qty to get
>Also what is added operation check box used for. If anyunreleased first. Does
>operation has to added to a realeased job, it has to be
ops, or
other unusual
started
getting into
this,
though.
-Wayne
access/share Report
time you
password,
save the
Files,
try it, go to
My Groups,
the link above
