MES on a windows XP computer - 9.05.700C
And sometimes when you cant load EPICOR because of a tmp file.  Use cleanmgr
Windows Disk Cleanup along with the other suggestions.
Miguel A. Santillan
Compass Manufacturing Systems
Sent: Friday, January 16, 2015 5:44 AM
Subject: RE: [Vantage] MES on a windows XP computer - 9.05.700C
Yep it worked…I just deleted the local cache under c:\documents and settings\all users\application folder\epicor
Man, talk about pulling stuff out of the cobwebs!
Thanks, guys!
Sent: Friday, January 16, 2015 7:34 AM
To: Vantage
Subject: Re: [Vantage] MES on a windows XP computer - 9.05.700C
Of what VIc suggested doesn't work try deleting the files here
We are currently working with the Microsoft CLR Security team on this issue. As a work around can you please delete the following .cch files. %UserProfile%\AppData\Roaming\Microsoft\CLR Security Config\ 2.0.50727.312\security.config.cch And any CCH Files in the following directory. C:\Windows\Microsoft.NET\Framework \2.0.50727\CONFIG Also what templates were you last working with in CodeSmith? What version of Visual Studio are you using? Thanks
Jose C Gomez
Software Engineer
T: 904.469.1524 mobile
On Fri, Jan 16, 2015 at 8:26 AM, 'Vic Drecchio' vic.drecchio@... [vantage] <vantage@yahoogroups.com> wrote:
Try changing the Alternate Cache Folder value in your client's .mfgsys file in C:\client803\config
Look for this value:       <AlternateCacheFolder value="" />
and then make a folder like C:\MANASA
And then put that folder value in    <AlternateCacheFolder value="C:\MANASA" />
Relogin to Epicor
Sent: Friday, January 16, 2015 8:17 AM
Subject: [Vantage] MES on a windows XP computer - 9.05.700C
Ok we are getting the Mfgsys.exe error message that it has encountered a problem and needs to close message.  You know the one where it then asks if you want to Send the error to Microsoft or not.
We have reinstalled the client, we took a copy of the file from the server and pasted it and nothing has worked.  Anything else we may need to try since it has been so long since I have had to deal with windows XP?
TIA, Manasa
TIA, Manasa
Relogin to Epicor
TIA, Manasa
Jose C Gomez
Software Engineer
Quis custodiet
ipsos custodes?
On Fri, Jan 16, 2015 at 8:26 AM, ‘Vic Drecchio’ vic.drecchio@… [vantage] <vantage@yahoogroups.com> wrote:
Â
<div>
  <p></p><div><p class="ygrps-yiv-1471163024MsoNormal"><span style="font-size:11.0pt;color:#44546a;">Try changing the Alternate Cache Folder value in your client&#39;s .mfgsys file in C:&#92;client803&#92;config<u></u><u></u></span></p><p class="ygrps-yiv-1471163024MsoNormal"><span style="font-size:11.0pt;color:#44546a;"><u></u> <u></u></span></p><p class="ygrps-yiv-1471163024MsoNormal"><span style="font-size:11.0pt;color:#44546a;">Look for this value:       &lt;AlternateCacheFolder value=&quot;&quot; /&gt;<u></u><u></u></span></p><p class="ygrps-yiv-1471163024MsoNormal"><span style="font-size:11.0pt;color:#44546a;"><u></u> <u></u></span></p><p class="ygrps-yiv-1471163024MsoNormal"><span style="font-size:11.0pt;color:#44546a;">and then make a folder like C:&#92;MANASA<u></u><u></u></span></p><p class="ygrps-yiv-1471163024MsoNormal"><span style="font-size:11.0pt;color:#44546a;"><u></u> <u></u></span></p><p class="ygrps-yiv-1471163024MsoNormal"><span style="font-size:11.0pt;color:#44546a;">And then put that folder value in    &lt;AlternateCacheFolder value=&quot;C:&#92;MANASA&quot; /&gt;<u></u><u></u></span></p><p class="ygrps-yiv-1471163024MsoNormal"><span style="font-size:11.0pt;color:#44546a;"><u></u> <u></u></span></p><p class="ygrps-yiv-1471163024MsoNormal"><span style="font-size:11.0pt;color:#44546a;">Relogin to Epicor<u></u><u></u></span></p><p class="ygrps-yiv-1471163024MsoNormal"><span style="font-size:11.0pt;color:#44546a;"><u></u> <u></u></span></p><div><div style="border-top:solid #b5c4df 1.0pt;padding:3.0pt 0in 0in 0in;"><p class="ygrps-yiv-1471163024MsoNormal"><b><span style="font-size:10.0pt;">From:</span></b><span style="font-size:10.0pt;"> <a rel="nofollow" target="_blank" href="mailto:vantage@yahoogroups.com">vantage@yahoogroups.com</a> [mailto:<a rel="nofollow" target="_blank" href="mailto:vantage@yahoogroups.com">vantage@yahoogroups.com</a>] <br><b>Sent:</b> Friday, January 16, 2015 8:17 AM<br><b>To:</b> <a rel="nofollow" target="_blank" href="mailto:vantage@yahoogroups.com">vantage@yahoogroups.com</a><br><b>Subject:</b> [Vantage] MES on a windows XP computer - 9.05.700C<u></u><u></u></span></p></div></div><span class="ygrps-yiv-1471163024"><p class="ygrps-yiv-1471163024MsoNormal"><u></u> <u></u></p><p class="ygrps-yiv-1471163024MsoNormal">  <u></u><u></u></p><div><div><div><div><p class="ygrps-yiv-1471163024MsoNormal">Ok we are getting the Mfgsys.exe error message that it has encountered a problem and needs to close message.  You know the one where it then asks if you want to Send the error to Microsoft or not.<u></u><u></u></p><p class="ygrps-yiv-1471163024MsoNormal"> <u></u><u></u></p><p class="ygrps-yiv-1471163024MsoNormal">We have reinstalled the client, we took a copy of the file from the server and pasted it and nothing has worked.  Anything else we may need to try since it has been so long since I have had to deal with windows XP?<u></u><u></u></p><p class="ygrps-yiv-1471163024MsoNormal"> <u></u><u></u></p><p class="ygrps-yiv-1471163024MsoNormal">TIA, Manasa<u></u><u></u></p><p class="ygrps-yiv-1471163024MsoNormal"> <u></u><u></u></p></div></div><div><p class="ygrps-yiv-1471163024MsoNormal"><span style="color:white;"><u></u><u></u></span></p></div></div></div></span></div><p></p>
</div>
<div style="color:#fff;min-height:0;"></div>
Thanks, guys!
To: Vantage
Jose C Gomez
Software Engineer
Relogin to Epicor
TIA, Manasa
