MES Sub Process Customization deployment
Struggling a bit with deployment of a customization within the MES screen
Customization is on the Serial Number Selection Process…called from the Customer Shipment Entry Form Launched through MES and through standard interface.
Process Menu Item has been created and the Process Calling Maintenance set to match. This works perfectly for standard interface. For MES we cannot get the customization to launch at all.
From Developer Mode when we launch the Serial Number Selection we get these values
How do we apply a process call without a MenuID to match up with the customization
:grimacing:
This is how ours is setup
Not sure I understand the problem.
Called Process Reference = Process Key
Called From = Calling App
Menu ID in Process Calling Maintenance is the Menu that will be called when there is a match to the above.
That configuration will launch UDCWW menu for your example.
Thank you!
Chalk this one up to a typo in the Process Calling Maintenance setup. :man_facepalming:
