Method Tracker on the Menu
Brian,
You were right! Thank you very much!! Smack dab in front of me too.
Kurt
--- In vantage@yahoogroups.com, "Brian Roberts" <broberts@...> wrote:
> I think its the last parameter to BOMTrackerArgs, try changing it to
> false.
> Brian.
> Of Kurt
> Sent: Thursday, October 11, 2012 11:25 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Method Tracker on the Menu
> Hi,
> I gave this a try and it works great. I have it working where the user
> can search, or enter their own part,rev and alt to call up. Thanks very
> much for the code!! But, it looks like (at least the way it works for
> us) when the Method Tracker comes up, it's full blown modal. No other
> forms in Vantage can be used when the MT opens from there. That doesn't
> happen when it's opened from the Part Tracker. Does anyone have an idea
> how to open the MT "de-modalized"?
> Thanks!!
> Kurt
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
> Miguel Santillan <msantillan@> wrote:
> > Thanks will try that out.
> > Miguel A. Santillan
> > Compass Components, Inc.
> > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> Behalf Of bw2868bond
> > Sent: Thursday, August 30, 2012 3:42 PM
> > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > This is what we did on 8.03.405a
> > Take a simple entry form and hide/move all the base controls.
> > Add a button to the blank form.
> > Here is the code customization that will allow the user to select the
> assembly - rev and launch Method Tracker:
> > '// Custom VB.NET code for UD40Form
> > '// Created: 8/11/2008 10:11:15 AM
> > Imports System
> > Imports System.Data
> > Imports System.Diagnostics
> > Imports System.Windows.Forms
> > Imports System.ComponentModel
> > Imports Microsoft.VisualBasic
> > Imports Epicor.Mfg.UI
> > Imports Epicor.Mfg.UI.FrameWork
> > Imports Epicor.Mfg.UI.ExtendedProps
> > Imports Epicor.Mfg.UI.FormFunctions
> > Imports Epicor.Mfg.UI.Customization
> > Imports Epicor.Mfg.UI.Adapters
> > Imports Epicor.Mfg.UI.Searches
> > Imports Epicor.Mfg.BO
> > Module Script
> > '// ** Wizard Insert Location - Do Not Remove 'Begin/End Wizard Added
> Module Level Variables' Comments! **
> > '// Begin Wizard Added Module Level Variables **
> > '// End Wizard Added Module Level Variables **
> > '// Add Custom Module Level Variables Here **
> > Sub InitializeCustomCode()
> > '// ** Wizard Insert Location - Do not delete 'Begin/End Wizard Added
> Variable Intialization' lines **
> > '// Begin Wizard Added Variable Intialization
> > '// End Wizard Added Variable Intialization
> > '// Begin Custom Method Calls
> > '// End Custom Method Calls
> > End Sub
> > Sub DestroyCustomCode()
> Object Disposal' lines **
> > '// Begin Wizard Added Object Disposal
> > '// End Wizard Added Object Disposal
> > '// Begin Custom Code Disposal
> > '// End Custom Code Disposal
> > End Sub
> > Private Sub btnBomSearch_Click(ByVal Sender As Object, ByVal Args As
> System.EventArgs) Handles btnBomSearch.Click
> > '// ** Place Event Handling Code Here **
> > Dim recordSelected As Boolean
> > Dim dsSearch As DataSet = SearchFunctions.listLookup(UD40Form,
> "PartRevSearchAdapter", recordSelected, True, "", False)
> > If recordSelected
> > Dim bsa As Epicor.Mfg.UI.FormFunctions.BomTrackerArgs
> > bsa = New BomTrackerArgs(dsSearch.Tables(0).Rows(0)("PartNum"),
> dsSearch.Tables(0).Rows(0)("RevisionNum"),
> dsSearch.Tables(0).Rows(0)("AltMethod"), true)
> > Dim mt As Object = ProcessCaller.LaunchTracker(UD40Form, "XAGO3000",
> bsa)
> > End If
> > End Sub
> > End Module
> <mailto:vantage%40yahoogroups.com>, Miguel Santillan
> <msantillan@<mailto:msantillan@>> wrote:
> > > How can I get the Method Tracker on the menu. Is it possible?
> > > App.EngWorkBenchEntry.BOMTrackerForm
> > > Regards,
> > > Miguel A. Santillan
> > > ERP Administrator
> > > 510-661-6666 Office
> > > 510-656-0603 Fax
> msantillan@<mailto:msantillan@<mailto:msantillan@%3cmailto:msantillan@>.
> > > www.ccicms.com<http://www.ccicms.com/>
Regards,
Miguel A. Santillan
ERP Administrator
510-661-6666 Office
510-656-0603 Fax
msantillan@...<mailto:msantillan@...>
Not that I am aware of and I believe even if you could it wouldn't be of much use. The part number input field is locked when the method tracker is launched so you wouldn't be able to enter a part number to look-up. There might be a switch or entry point that would allow you to do it but nothing I have found or aware of so far.
Jim Kinneman
Encompass Solutions, Inc
> Regards,
> Miguel A. Santillan
> ERP Administrator
> 510-661-6666 Office
> 510-656-0603 Fax
Here is the code customization that will allow the user to select the assembly - rev and launch Method Tracker:
Imports System
Imports System.Data
Module Script
'// ** Wizard Insert Location - Do Not Remove 'Begin/End Wizard Added Module Level Variables' Comments! **
'// ** Wizard Insert Location - Do not delete 'Begin/End Wizard Added Variable Intialization' lines **
End Sub
'// ** Wizard Insert Location - Do not delete 'Begin/End Wizard Added Object Disposal' lines **
End Sub
Private Sub btnBomSearch_Click(ByVal Sender As Object, ByVal Args As System.EventArgs) Handles btnBomSearch.Click
Dim dsSearch As DataSet = SearchFunctions.listLookup(UD40Form, "PartRevSearchAdapter", recordSelected, True, "", False)
If recordSelected
bsa = New BomTrackerArgs(dsSearch.Tables(0).Rows(0)("PartNum"), dsSearch.Tables(0).Rows(0)("RevisionNum"), dsSearch.Tables(0).Rows(0)("AltMethod"), true)
Dim mt As Object = ProcessCaller.LaunchTracker(UD40Form, "XAGO3000", bsa)
End If
End Sub
End Module
> Regards,
> Miguel A. Santillan
> ERP Administrator
> 510-661-6666 Office
> 510-656-0603 Fax
Miguel A. Santillan
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of bw2868bond
Imports System
Imports System.Data
Module Script
End Sub
End Sub
If recordSelected
End If
End Sub
End Module
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Miguel Santillan <msantillan@...<mailto:msantillan@...>> wrote:
> Regards,
> Miguel A. Santillan
> ERP Administrator
> 510-661-6666 Office
> 510-656-0603 Fax
> msantillan@...<mailto:msantillan@<mailto:msantillan@...%3cmailto:msantillan@>...>
Hi,
I gave this a try and it works great. I have it working where the user can search, or enter their own part,rev and alt to call up. Thanks very much for the code!! But, it looks like (at least the way it works for us) when the Method Tracker comes up, it's full blown modal. No other forms in Vantage can be used when the MT opens from there. That doesn't happen when it's opened from the Part Tracker. Does anyone have an idea how to open the MT "de-modalized"?
Thanks!!
Kurt
> Miguel A. Santillan
> Imports System
> Imports System.Data
> Module Script
> End Sub
> End Sub
> If recordSelected
> End If
> End Sub
> End Module
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Miguel Santillan <msantillan@<mailto:msantillan@>> wrote:
> > Regards,
> > Miguel A. Santillan
> > ERP Administrator
> > 510-661-6666 Office
> > 510-656-0603 Fax
> > msantillan@<mailto:msantillan@<mailto:msantillan@%3cmailto:msantillan@>...>
false.
Brian.
Of Kurt
Hi,
Thanks!!
Kurt
> Miguel A. Santillan
> Imports System
> Imports System.Data
> Module Script
> End Sub
> End Sub
> If recordSelected
bsa)
> End If
> End Sub
> End Module
> > Regards,
> > Miguel A. Santillan
> > ERP Administrator
> > 510-661-6666 Office
> > 510-656-0603 Fax
