I'm running 2k3 with the Citrix XP Server and have no problems, the
way Vantage is run had to be tweaked a little but besides that I have
no porblems, the benefits are endless, starting from low bandwith
needs (I run 20 citrix users over a 11b wireless and have no delay) to
user helpdesk (the shadow function in CItrix is so much better than
remote control over TS)
I suggest Citrix, if you need to know what has to be changed, just
write me and I'll give you the scoop.
Thomas
Thomas
--- In vantage@yahoogroups.com, "Bruce Butler" <bbutler@k...> wrote:
> We have recently made the decision to implement terminal server 2k3 in
> conjunction with Citrix server. With the postings I have read recently,
> it sounds like a lot of you are swaying away from Citrix and simply
> implementing 2K3 terminal services. I would like to see if I could get
> some kind of consensus as to what the group's recommendation on this
> would be.
> The main reason I have decided to go with Citrix is because of the lack
> of administrative information I get from our current installation of Win
> 2K terminal services.
> Thank you,
> Bruce Butler, IT Manager
> Knappe & Koester
> 18 Bradco St
> Keene, NH 03431
> bbutler@k...
> p.603.355.1166
> f. 603.355.2266
