Part ABC Codes - Minimum & System
Thanks Patty.
Much appreciated (and a bit of relief!)
Rob
--- On Fri, 3/6/09, bpbuechler <pbuechler@...> wrote:
Subject: [Vantage] Re: Part ABC Codes - Minimum & System
Date: Friday, March 6, 2009, 9:42 AM
Capture did not change the System ABC Code.
And I have not found any ChgLogs that were a change, but rather new PartPlant records. So at this point...it is a bit of an unknown. We have someone comparing daily and still nothing has turned up. But once it does...I will let this group know if there is something funky going on.
Patty Buechler
--- In vantage@yahoogroups .com, Robert Brown <robertb_versa@ ...> wrote:
> Patty,
> What did you discover on this issue?
> (Is there a 'ghost in the Vantage machine' changing ABC codes without our knowledge?)
> Rob
> --- On Tue, 2/24/09, bpbuechler <pbuechler@. ..> wrote:
> From: bpbuechler <pbuechler@. ..>
> To: vantage@yahoogroups .com
> Date: Tuesday, February 24, 2009, 2:21 PM
> I just turned it on this morning :)
> And since Capture will occur this weekend, I should have an answer
> soon. I was just wondering if anyone else has seen this...
> I will update the group if Capture is the culprit.
> Thanks
> Patty
> --- In vantage@yahoogroups .com, "Mike Lowe" <MLowe@> wrote:
> > Do you have the Change Logs turned on? Perhaps this will yield some
> > clues...
> > Mike Lowe
> > Corporate I.T. Manager
> > Connor Manufacturing Services
> > Direct:
> > Fax:
> > Cell:
> > Skype: Mike.Lowe
> > Email: MLowe@ <mailto:MLowe@ ...>
> > Web: www.connorms. com <http://www.connorms .com/>
> > ____________ _________ _________ __
> > From: vantage@yahoogroups .com [mailto:vantage@ yahoogroups .com] On
> Behalf
> > Of bpbuechler
> > Sent: Tuesday, February 24, :19 AM
> > Subject: [Vantage] Part ABC Codes - Minimum & System
> > So we really hate Vantage Cycle Count Process. Additionally, this
> is
> > not part of E9...UGH! Ok...I am off that soapbox.
> > My issue is the System ABC Codes are changing and I cannot
> determine
> > how or why.
> > It is my understanding the Calculate ABC Code process should be the
> > only process that updates the System ABC Code. However, I am
> > suspicious of the Cost Capture.
> > We have circumvented the system and made the System ABC Code
> > available for us to manually override/set. Therefore when we run
> > Cycle Count, we know what Parts it should be pulling.
> > Since we upgraded from 8.03.404B to 8.03.405, we have noticed the
> > System ABC Codes are changing. We are not running the Calculate (no
> > one has access to it) and no one is manually changing 5,000 parts
> at
> > one time.
> > Anyone seen this or experienced this kind of thing?
> > TIA for suggestions
> > Patty Buechler
> > ____________ _________ _________ _________ _________ ______
> > This email transmission and any attached documents are for the sole
> use
> > of the intended recipient(s) . If you are not the intended recipient,
> > disclosure, reproduction or distribution of this information is
> > prohibited and may be unlawful. If you believe you have received
> this
> > information in error, please inform the sender immediately and
> > permanently delete all copies and attachments of this transmission.
> > Thank you for your cooperation.
> ____________ _________ _________ _________ _________ _________ _
> > This email has been scanned by the MessageLabs Email Security
> System.
> > For more information please visit http://www.messagel abs.com/email
So we really hate Vantage Cycle Count Process. Additionally, this is
My issue is the System ABC Codes are changing and I cannot determine
how or why.
one has access to it) and no one is manually changing 5,000 parts at
one time.
TIA for suggestions
Patty Buechler
clues...
Mike Lowe
Direct: (949) 713-3328
Fax: (949) 666-5268
Cell: (949) 973-7621
Skype: Mike.Lowe
Email: MLowe@... <mailto:MLowe@...>
Web: www.connorms.com <http://www.connorms.com/>
Of bpbuechler
Sent: Tuesday, February 24, 2009 10:19 AM
how or why.
one time.
TIA for suggestions
Patty Buechler
______________________________________________________
This email transmission and any attached documents are for the sole use
of the intended recipient(s). If you are not the intended recipient,
prohibited and may be unlawful. If you believe you have received this
______________________________________________________________________
This email has been scanned by the MessageLabs Email Security System.
For more information please visit http://www.messagelabs.com/email
Patty
> clues...
> Mike Lowe
> Fax: (949) 666-5268
> Skype: Mike.Lowe
Behalf
> Of bpbuechler
is
determine
> how or why.
at
> one time.
> TIA for suggestions
> Patty Buechler
use
this
System.
The Cycle Count process changed A LOT in E9. I'd like to hear you speak from
the soapbox. Our complaint is how parts are chosen for a cycle count and I'm
actually working on a BPM Base program to replace the default Epicor 9
behavior.
> how or why.
There's the minimum ABC code on PartPlant record that can affect the ABC
code too. So when you when you do your ChangeLog, remember to check that one
too.
Mark W.
That was my point; you have very limited capabilities in how it
selects parts. Once the Tags are Generated...it is a pretty straight
forard process. The selection process has been a topic at
Perspectives for more than 4 years. You would have thought they had
enough complaints and fixed it with all the enhancments to inventory
on E9...
The last bugger we found is when you limit your selection of parts by
25. It finds the right 25 parts (based on the ABC Code and Last
Count Date) but brings them into the Count Group Entry by the Part #
not by the ABC Code. If my time is limited and I don't get to the
last 5 items, I could be missing to count A items when I have counted
a D item. I would rather it list the parts by the priority of it
being counted...ABC Code should be the first in the hierarchy, then
Last Counted Date, then list by Part #. Better yet...give me the
option to control that.
Thanks to all for your updates and advice.
Patty
is
speak from
count and I'm
Epicor 9
> behavior.
determine
> > how or why.
the
the ABC
that one
> too.
> Mark W.
Patty,
I suppose you could always modify your tag report to indicate whether the part is A, B or C (giving you the option on focusing on A's when time run short and voiding the rest for another day).
It wouldn't be much of a stretch to write a BAQ that includes the ABC code of parts in in-process count groups... Either view it as a simple BAQ search from Part Tracker or convert it to a dashboard.
Workable ???
Safe bet most know I'm not a fan of Vantage... But I've seen cycle count processes much worse than this one. (Most of them out there leave much to be desired.)
Rob
Date: Wednesday, February 25, 2009, 8:12 AM
selects parts. Once the Tags are Generated... it is a pretty straight
on E9...
Patty
is
speak from
count and I'm
Epicor 9
> behavior.
determine
> > how or why.
the
the ABC
that one
> too.
> Mark W.
Patty,
Rob
Patty
> clues...
> Mike Lowe
> Direct:
> Fax:
> Cell:
> Skype: Mike.Lowe
> Email: MLowe@... <mailto:MLowe@ ...>
> From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On
Behalf
> Of bpbuechler
is
determine
> how or why.
at
> one time.
> TIA for suggestions
> Patty Buechler
use
this
System.
Patty Buechler
--- In vantage@yahoogroups.com, Robert Brown <robertb_versa@...> wrote:
> Patty,
> Rob
> From: bpbuechler <pbuechler@...>
> Thanks
> Patty
> > clues...
> > Mike Lowe
> > Direct:
> > Fax:
> > Cell:
> > Skype: Mike.Lowe
> Behalf
> > Of bpbuechler
> is
> determine
> > how or why.
> at
> > one time.
> > TIA for suggestions
> > Patty Buechler
> use
> this
> System.
