Hi all,
I got the following exception when trying to inactive a part but seems there are no suggestions , jobs nor POs. What I found was quote material. is this the reason why I cannot inactive the part?
Best regards,
Business Layer Exception
Part cannot be marked Inactive, open Purchase Order records exist.
Error Detail
Description: Part cannot be marked Inactive, open Purchase Order records exist.
Program: Erp.Services.BO.Part.dll
Method: PartBeforeUpdate
Line Number: 9389
Column Number: 21
Table: InActive
Server Trace Stack: at Erp.Services.BO.PartSvc.PartBeforeUpdate() in c:_Releases\ERP\UD10.1.400.17\Source\Server\Services\BO\Part\Part.cs:line 9389
at Erp.Services.BO.PartSvc.OnRowEvent(DataTableEventType type, String tableName, IceRow row) in c:_Releases\ERP\UD10.1.400.17\Source\Server\Services\BO\Part\Part.Designer.cs:line 1441
at Ice.Services.Trace.TablesetProfilingCollector.DoRowEventTrace(String tableName, String methodName, Int32 rowCount, Action action) in c:_Releases\ICE\3.1.400.17\source\Framework\Epicor.Ice\Services\TablesetProfilingCollector.cs:line 146
at Ice.TablesetBound3.UpdateRow(IceDataContext dataContext, Int32 tableNum, IIceTable table, IceRow updatedRow, IceRow originalRow, TablesetProfilingCollector parentTraceCollector) in c:\_Releases\ICE\3.1.400.17\source\Framework\Epicor.Ice\Services\TablesetBound.cs:line 1155 at Ice.TablesetBound3.WriteTable(IceDataContext dataContext, Int32 tableIndex, IIceTable table, TablesetProfilingCollector parentTraceCollector) in c:_Releases\ICE\3.1.400.17\source\Framework\Epicor.Ice\Services\TablesetBound.cs:line 893
at Ice.TablesetBound3.InnerUpdate(IceDataContext dataContext, TFullTableset tableset) in c:\_Releases\ICE\3.1.400.17\source\Framework\Epicor.Ice\Services\TablesetBound.cs:line 796 at Erp.Services.BO.PartSvc.Update(PartTableset& ds) in c:\_Releases\ERP\UD10.1.400.17\Source\Server\Services\BO\Part\Part.Designer.cs:line 5583 at Epicor.Customization.Bpm.MethodCustomizationBase23.RunDirectives(TParam parameters) in c:_Releases\ICE\3.1.400.17\source\Server\Internal\Lib\Epicor.Customization.BPM\MethodCustomizationBase2.cs:line 218
at Epicor.Customization.Bpm.CustomizationBase23.Execute(TParam parameters) in c:\_Releases\ICE\3.1.400.17\source\Server\Internal\Lib\Epicor.Customization.BPM\CustomizationBase2.cs:line 77 at Epicor.Customization.Bpm.BOBFD5A4E3608E411A8E2CD99448EFF17A.PartSvcCustomization.Update(PartTableset& ds) at Erp.Services.BO.PartSvcFacade.Update(PartTableset& ds) in c:\_Releases\ERP\UD10.1.400.17\Source\Server\Services\BO\Part\PartSvcFacade.cs:line 549 at SyncInvokeUpdate(Object , Object[] , Object[] ) at System.ServiceModel.Dispatcher.SyncMethodInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs) at Epicor.Hosting.OperationBoundInvoker.InnerInvoke(Object instance, Func2 func) in c:_Releases\ICE\3.1.400.17\source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 59
at Epicor.Hosting.OperationBoundInvoker.Invoke(Object instance, Func2 func) in c:\_Releases\ICE\3.1.400.17\source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 28 at Epicor.Hosting.Wcf.EpiOperationInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs) in c:\_Releases\ICE\3.1.400.17\source\Framework\Epicor.System\Hosting\Wcf\EpiOperationInvoker.cs:line 23 at System.ServiceModel.Dispatcher.DispatchOperationRuntime.InvokeBegin(MessageRpc& rpc) at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage5(MessageRpc& rpc) at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage11(MessageRpc& rpc) at System.ServiceModel.Dispatcher.MessageRpc.Process(Boolean isOperationContextSet) at System.ServiceModel.Dispatcher.ChannelHandler.DispatchAndReleasePump(RequestContext request, Boolean cleanThread, OperationContext currentOperationContext) at System.ServiceModel.Dispatcher.ChannelHandler.HandleRequest(RequestContext request, OperationContext currentOperationContext) at System.ServiceModel.Dispatcher.ChannelHandler.AsyncMessagePump(IAsyncResult result) at System.ServiceModel.Dispatcher.ChannelHandler.OnAsyncReceiveComplete(IAsyncResult result) at System.Runtime.Fx.AsyncThunk.UnhandledExceptionFrame(IAsyncResult result) at System.Runtime.AsyncResult.Complete(Boolean completedSynchronously) at System.ServiceModel.Channels.SecurityChannelListener1.ReceiveItemAndVerifySecurityAsyncResult`2.InnerTryReceiveCompletedCallback(IAsyncResult result)
at System.ServiceModel.Channels.TransportDuplexSessionChannel.TryReceiveAsyncResult.OnReceive(IAsyncResult result)
at System.ServiceModel.Channels.SynchronizedMessageSource.ReceiveAsyncResult.OnReceiveComplete(Object state)
at System.ServiceModel.Channels.SessionConnectionReader.OnAsyncReadComplete(Object state)
at System.Net.LazyAsyncResult.Complete(IntPtr userToken)
at System.Net.LazyAsyncResult.ProtectedInvokeCallback(Object result, IntPtr userToken)
at System.Net.Security.NegotiateStream.ProcessFrameBody(Int32 readBytes, Byte buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest)
at System.Net.Security.NegotiateStream.ReadCallback(AsyncProtocolRequest asyncRequest)
at System.Net.AsyncProtocolRequest.CompleteRequest(Int32 result)
at System.Net.FixedSizeReader.CheckCompletionBeforeNextRead(Int32 bytes)
at System.Net.FixedSizeReader.ReadCallback(IAsyncResult transportResult)
at System.ServiceModel.Channels.ConnectionStream.IOAsyncResult.OnAsyncIOComplete(Object state)
at System.Net.Sockets.SocketAsyncEventArgs.OnCompleted(SocketAsyncEventArgs e)
at System.Net.Sockets.SocketAsyncEventArgs.FinishOperationSuccess(SocketError socketError, Int32 bytesTransferred, SocketFlags flags)
at System.Net.Sockets.SocketAsyncEventArgs.CompletionPortCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* nativeOverlapped)
at System.Threading._IOCompletionCallback.PerformIOCompletionCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* pOVERLAP)Client Stack Trace
at Epicor.ServiceModel.Channels.ImplBase`1.ShouldRethrowNonRetryableException(Exception ex, DataSet dataSets)
at Erp.Proxy.BO.PartImpl.Update(PartDataSet ds)
at Ice.Lib.Framework.EpiBaseAdapter.Update()
at Erp.UI.App.PartEntry.PartTransaction.AdapterUpdate()
at Erp.UI.App.PartEntry.PartTransaction.UpdateX()
