Paste/Insert Operations - Engineering Workbench
Epicor 10.2.500.30
Is it possible to paste/insert data in the Engineering Workbench Method of Manufacturing Operations List? When attempting, we receive an error
-jp
Yes it is, but you need to have the fields in the correct order. you only need the Operation Code and Time as the first two fields, and then that is all you need to paste in.
Thanks Tim, by Operation Code, do you mean the Operation, or the Opr Seq, and for Time would it be the Prod. Std?
You actually dont need to paste in the operation sequence because it will create them as it goes. but you do need to paste in the operation (or op code?) which points to the operation. There is also an operation description, which will auto populate once you choose an operation.
