PO - Part Class , [Enter] as Tab
Bart,
I agree, you should work with the accounting dept if there are GL
accounts set up through the part class as
this determines you book to physical inventory settings.
If you change a class at the PO level and the gl setting is different it
will create an irreconcilable inventory balance.
Here's some food for thought.
GL accounts for inventory are set by the Part Class, the Part GL
account, from the Vendor GL account, or the PO
or company configuration and this all depends on your current inventory
valuation methods.
You may also want to get familiar with the Inventory Transaction
Hierarchy from Epicor for your current release.
_____
Of Bartosz Niemczewski
Sent: Wednesday, February 18, 2009 6:57 AM
To: Vantage Group
Subject: [Vantage] PO - Part Class , [Enter] as Tab
Hello,
When we create a new PO and new PO Line on form Details field Class is
disabled. Is anybody know how to enable this option to give our users
make changes.
Another question is , after we check this option "[Enter] as Tab" in
menu options Enter works as a TAB for comments, too. Is any way to
change "[Enter] as Tab" to "Enter as Enter" for comments only.
We know that "ctrl+enter" works and it takes us to next line and it is
easy for us , but I think it could be confusing for our users.
Thank you.
Bart.
NOTICE OF CONFIDENTIALITY: This e-mail message, including attachments, is for the sole use of the intended recipients and may contain confidential and privileged information. If you are not an intended recipient, please contact the sender by reply e-mail and destroy all copies of this message, including attachments. Any unauthorized review, use, disclosure or distribution is prohibited.
Hello,
Â
When we create a new PO and new PO Line on form Details field Class is disabled. Is anybody know how to enable this option to give our users make changes.
Â
Another question is , after we check this option "[Enter] as Tab" in menu options Enter works as a TAB for comments, too. Is any way to change "[Enter] as Tab" to "Enter as Enter" for comments only.
Â
We know that "ctrl+enter" works and it takes us to next line and it is easy for us , but I think it could be confusing for our users.
Â
Thank you.
Â
Bart.
That happens because the part, in part maintenance, has a part class
associated to it.
I would hate to mention this, but if you delete the part class from the
part, in part maintenance, then it will be open.
I hate this because if your guys forget to fill in the class on the PO,
the cost of the part hits GL accounts your accountant will hate to see.
You may want to discuss this with the accountant at your company first.
HTH
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
Sent: Wednesday, February 18, 2009 8:57 AM
To: Vantage Group
Hello,
make changes.
Thank you.
Bart.
