Prevent Users from loging into full epicor(DefaultUser)
Hi All,
Is there a way to prevent Production employees that uses MES or Handhelds from logging in into the full version in epicor.
This causes that office employees get kick out from epicor cause there are not enough licenses available (defaultUsers) , currently we are using Epicor 10.1.17
Not a fool proof plan, but remove the shortcuts from their PC?
Yes we have done that but still they know how to work around it :slight_smile:
Then the question is why are they going inthere? I mean you could stop them sure… however if they are defying your rules perhaps is a training issue.
An this is where the lack of Management control over people collide with Technology. An on going issue i have seen many places. Management not holding there employees accountable and wanting technology to fix the problem.
If you have rules in place and they circumvent them, I’d suggest logging who is breaking those rules and can them.
Ding ding ding, this isn’t a software issue. There is a perfectly workable software solution which is don’t give them anything but MES shortcuts. If the employee is “working around it” it is not a problem that should be solved by IT it should be solved by slapping their hands
I know this isn’t what you asked I’m sorry it is just frustrating to see this stuff.
Another less totalitarian approach might be to find out WHY they want/need the full client
The only other thing I can think of is to not allow multiple sessions. It can be a pain if not used to it but we made that change when we went to 9.05 years ago…in the long run…it has worked out fine.
Hold them accountable and also have floater licenses, looks like 1 or 2 logins extra, disrupt your business. :slight_smile:
Thank you guys for your input , yeah I guess we are going to do the simple route, remove the icons and educate the people of not messing around with them.
Thanks again for all your input its really helpful.
RCA why they are going in there. If they are going after one particular screen make it available in MES
But I have a question here… logging in MES doesn’t that use one Epicor license anyway?
tks.
No it uses Data Collection Lic
unless they are out of data collection lic, then it uses a full doesn’t it?
Rightyar!
So is it possible that the users aren’t actually logging into the full version, but maybe there aren’t enough MES licenses so they are taking up enough licenses to start taking up full licenses and causing problems?
Really ?? I had no idea.
Yea there are some really surprising approaches to licensing and fallback / penalties that made a lot of sense in the early 90s when the licensing was written but nowadays is just odd. Maybe not wrong but surprising is not a great experience. There has been a desire to clean up the licensing due to these kinds of tickets sent in that don’t make customers very satisfied. Of course if you make any change in licensing everyone gets mad at you so not sure if/when this will get tackled. If/When this occurs, remember this conversation on why a change was made. I am sure it will make people mad and they will miss the old days of licensing and forget all these oddities.
I was hoping for a checkbox in the user maintenance for MES ONLY.
