Are you sure, when I tested this in early access it did. MRP deletes all
unfirm jobs.(Your case the old revision), It then consumes the forecast and
creates new jobs to meet this. (In your case grabbing the new revision) You
may need to unapprove the old revision, I'm not sure. The only down side I
found is that it will eat up job numbers because if it creates a 1000 jobs
and you firm up job 900, when it deletes unfirm and starts creating again it
starts at 901 and does'nt reuse 1-900.
Patrick J. Winter
Information Services Manager
sSc Specialty Screw Corporation
Sent: Thursday, July 27, 2000 08:09 AM
To: vantage@egroups.com
Subject: Re: [Vantage] RE: Call Number 583663MPS Technical Support
Reply: JM - Mass ABOM replace
Our testing has shown this doesn't work. It apparently does
not look at BOM/routing changes, only sales order/forecast/
mps changes.
Patrick J. Winter
mps changes.
> The MRP module will do this for you on jobs that are unfirm.
> (Remove the old job and create a new one with the latest rev.)
> This is perfect for work center, work center rate changes, any updates to
> part routings.
