If you could please send me the screen shots, I'd sure appreciate it. I
tried what you suggested - step by step - and still can't seem to find the
local computer/printer on the remote system. :-(
Does it make a difference if the local computer I was working on was XP
rather than 7?
Thanks!!
_____
DD
Sent: Thursday, April 07, 2011 3:37 PM
Subject: Re: [Vantage] Remote printing
From the remote desktop connections - select Options from the left bottom of
the
screen.
Then select the local Resources tab.
Check the box for printers
Select the more button under printers - to add the local drives
Check the drives checkbox to be able to access the local hard drives
Check the other supported plug and play devices to be able to access the USB
flash drives
Hit ok.
Then select the Gereral tab and hit save to save these settings. (Very
important that the settings be saved - do not select save as)
Now when you use remote desktop then you should be able to select the local
printers (Usually it will be the default)
You will be able to read / write to your local hard drives - they show up as
attached drives.
If you have to install drivers on the workstation at the office then just
use
lpt1 port. It will be redirected when you remote in from home.
The install is just to get the drivers on the workstation. (I have not had
to
install the drivers after going to Windows 7 - only on old versions of RDP
back
on Windows XP)
I can send you the screenshots of the setups if you need.
I use it all the time and with many different printers / machines
From: Tricia Simon <t.simon@... <mailto:t.simon%40riten.com> >
Sent: Thu, April 7, 2011 1:12:46 PM
Subject: RE: [Vantage] Remote printing
Mark,
I'm trying to find something a little less cumbersome - sometimes there are
literally hundreds of pages that need to be printed.
But, I'm willing to try anything. As a non-techie..could you please explain
a little further the "shared disc feature"?
Thanks!!!
_____
Behalf Of
Mark Wonsil
Sent: Thursday, April 07, 2011 2:06 PM
Tricia asks
feature of RDP to copy to my home machine to view or print. Not
technically spectacular but it can save your butt when you need to
reprint.
Mark W.
rather than 7?
Thanks!!
_____
DD
the
screen.
flash drives
Hit ok.
attached drives.
use
to
back
on Windows XP)
Mark,
Thanks!!!
_____
Behalf Of
Mark Wonsil
Tricia asks
> We have a couple of folks who work from home (evenings and weekends). WeEach
> use a VPN to allow the Remote Desktop Connection to Vantage from home.
> person has a local printer attached to their home computer.Honestly, I Print Preview, export to PDF and use the shared disc
> Does anyone have any suggestions on how to print at home while performing
> activities in Vantage?
reprint.
Mark W.
