Shop floor employees to fix typos with qty
You can try an run the T&E Process ID through MES.  Add is to the button menu.
Miguel A. Santillan
Compass Manufacturing Systems
Sent: Tuesday, May 10, 2016 12:05 PM
Subject: [Vantage] shop floor employees to fix typos with qty
Is there a way in the MES for a shop floor employee to fix an erroneous qty right after he does it? Our example is with the laser, op 10 and he puts the asm number in instead of the qty. He then hits ok and it goes into the system. He sees his mistake and wants to fix it right away, but it looks like there is no way for him to fix it from the MES screen, he would have to go to the time and expense entry in the main program. Is that correct? I would like it for them to be able to fix it on his own. Does anyone have any suggestion on how we could make that work?
Disclaimer
The information contained in this communication from the sender is confidential. It is intended solely for use by the recipient and others authorized to receive it. If you are not the recipient, you are hereby notified that any disclosure, copying, distribution or taking action in relation of the contents of this information is strictly prohibited and may be unlawful.
