I used solution manager in 9.05.603, mostly successfully. Everything
except certain report styles & data definitions transferred the first
attempt. I built a second solution with those missing items only, and
it imported OK. The new menu items transferred, but the customizations
attached to existing menu items didn't, and I just updated manually. I
also think that sub process calling maintenance didn't transfer.
Brian.
Of Greg Payne
Sent: Wednesday, February 15, 2012 4:12 PM
Subject: [Vantage] Solution Manager 905.605
I used solution manager to move customizations from Test to Pilot and
none of them are on the menu choices.
It looks like the bams, dashboards, bpms all made it fine, even some
custom menu choices.
Has anyone used this for transferring them successfully? What could I
have missed.
I am starting to update the menu by hand, but will have to do a few more
before go live.
Greg Payne
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments,
is privileged and confidential. It is intended only for the exclusive
use of the addressee. If the reader of this message is not the intended
recipient, or the employee or agent responsible for delivering it to the
intended recipient, you are hereby notified that any dissemination,
distribution or copying of this communication is strictly prohibited. If
you have received this communication in error, please notify us at (727)
578-6258 and immediately delete the communication.
"This (document/presentation) may contain technical data as defined in
the International Traffic In Arms Regulations (ITAR) 22 CFR 120.10.
Export of this material is restricted by the Arms Export Control Act (22
U.S.C. 2751 et seq.) and may not be exported to foreign persons without
prior approval form the U.S. Department of State."
Brian.
Of Greg Payne
have missed.
before go live.
Greg Payne
