Frank, Butch,
Your answers work fine if the demand is for a job, we want to be able to
keep a minimum amount on hand for customer spare parts orders. Vantage will
not make a manufacturing suggestion to stock (without the MRP module), it
needs to be to either a sales order (which would be too late, we want it on
the shelf when the customer calls) or to a job. It looks like the Time
Phased report is the simplest way to go. We do both pull as assembly and
pull as material currently for manufacturing demands.
Liz
Sent: Tuesday, August 24, 2004 06:12 AM
Subject: RE: [Vantage] stocked manufactured items
if you want to be able to treat a manufactured part as a stock or planned
item the flag should set to pull as material not pull as assembly. If you
have set to pull as material the part will aggregate demand and then you can
make job(s) to satisfy it. If you have the flag set to pull as assembly the
manufactured child part will be part of the parents job, but you will not
have visibility of how many where made, used or even in "stock" because it
is treating it as a non-stock part. We have all of our parts set to stock.
The buyers go through the purchased time phase, and we are running mrp with
planning bills to satisfy all manufactured demand.
stock = pull as material or plan
non-stock = pull as assembly ( it doesn't exist at this level, roll up to
next level)
This was a little tricky for me it took many hours to break through my thick
Dutch head but now it has stuck.
GOOD LUCK
Frank Zeigafuse
Innovative Office Products
General Manager
Direct Phone: 610-559-6369
Email: fzeigafuse@...
Sent: Monday, August 23, 2004 7:33 PM
We're looking into this same issue for our implementation (ver 6.1). We
think the solution involves setting the Pull As Assy and View As Assy
flags to true. We're currently setting up a database to test it but you
may want to read the help file regarding the flags.
Butch
Sent: Monday, August 23, 2004 10:03 AM
Good morning everyone,
We have a number of manufactured items that we want to keep on hand for
spare parts for our customers. We've set up minimum on hand qty's, but
unfortunately Vantage will only make manufacturing suggestions for
manufactured items on a sales order or job. The two options we've come
up
with are to have a visual system in the warehouse (kanban, or similar);
or
creating a Crystal report to check for items below min and run it
weekly.
Is there anyone else out there that stocks manufactured items, and if so
how
do you handle it? Is this problem fixed in Sonoma?
Liz
Guntert & Zimmerman
Yahoo! Groups Sponsor
ADVERTISEMENT
click here
< http://us.ard.yahoo.com/SIG=1299ajniv/M=298184.5285298.6392945.3001176/
<http://us.ard.yahoo.com/SIG=1299ajniv/M=298184.5285298.6392945.3001176/>
D=groups/S=1705007183:HM/EXP=1093366936/A=2319501/R=0/SIG=11tq0u909/*htt
p://www.netflix.com/Default?mqso=60185353&partid=5285298>
< http://us.adserver.yahoo.com/l?M=298184.5285298.6392945.3001176/D=group
<http://us.adserver.yahoo.com/l?M=298184.5285298.6392945.3001176/D=group>
s/S=:HM/A=2319501/rand=856345888>
Yahoo! Groups Links
<http://groups.yahoo.com/group/vantage/>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service < http://docs.yahoo.com/info/terms/
<http://docs.yahoo.com/info/terms/> > .
ADVERTISEMENT
http://us.ard.yahoo.com/SIG=1290oc7d1/M=298184.5285298.6392945.3001176/D=gr
<http://us.ard.yahoo.com/SIG=1290oc7d1/M=298184.5285298.6392945.3001176/D=gr
http://www. <http://www.>
netflix.com/Default?mqso=60185353&partid=5285298> click here
http://us.adserver.yahoo.com/l?M=298184.5285298.6392945.3001176/D=groups/S=
<http://us.adserver.yahoo.com/l?M=298184.5285298.6392945.3001176/D=groups/S=
_____
Yahoo! Groups Links
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
< http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> > .
<www.LCDarms.com> -- Ergonomic mounting solutions for monitors and
keyboards
This e-mail is from Innovative Office Products, Inc. but expresses the views
of the sender and not necessarily the views of the company. The email and
any files transmitted with it are confidential to the intended recipient at
the e-mail address to which it has been addressed. It may not be disclosed
or used by any other than that addressee, nor may it be copied in any way.
If received in error, please delete and notify the sender via e-mail or
sales@... quoting the name of the sender. Messages sent via this
medium may be subject to delays, non-delivery and unauthorized alteration.
This e-mail has been prepared using information believed by the author to be
reliable and accurate. Unless expressly stated otherwise, this e-mail does
not form part of a legally binding contract or agreement between recipient
and Innovative Office Products, Inc.
Warning: Although Innovative Office Products, Inc. has taken reasonable
precautions to ensure no viruses are present in this email, we cannot accept
responsibility for any loss or damage arising from the use of this email or
attachments. It is, therefore, your responsibility to scan attachments (if
any).
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=129bsp6ib/M=298184.5285298.6392945.3001176/D=gr
oups/S=1705007183:HM/EXP=1093439524/A=2319498/R=0/SIG=11thfntfp/*http://www.
netflix.com/Default?mqso=60185352&partid=5285298> click here
:HM/A=2319498/rand=325245197>
_____
Yahoo! Groups Links
Liz
next level)
GOOD LUCK
Frank Zeigafuse
General Manager
Butch
up
or
weekly.
how
Liz
Guntert & Zimmerman
ADVERTISEMENT
click here
Yahoo! Groups Links
ADVERTISEMENT
>oups/S=1705007183:HM/EXP=1093390376/A=2319501/R=0/SIG=11tq0u909/*
>:HM/A=2319501/rand=674252236>
_____
Yahoo! Groups Links
keyboards
any).
ADVERTISEMENT
_____
Yahoo! Groups Links
