In our experiences, 7175 is normally a network issue - common when connecting over wireless networks.
Invalid session - are you running up to the limit of licenses? We have seen Invalid session errors when more people are logging into Epicor than we had licenses - or if people have multiple sessions and are using more than one session running. When user connections are idle, the system will allow their license to be re-used by a new client session, which drops the idle session. We removed multiple sessions from most users expect those that required them, like MES users, this solved our problem. Do you ever have a problem getting a new session after this occurs?
Tim
Tim
--- In vantage@yahoogroups.com, Tony Hughes <thughes281@...> wrote:
> Occasionally I come back to my desk and find an "Invalid Session" popup at which point I need to close the client and reopen.
> It rarely also happens while I'm clearly using the application, not leaving it idle.
> Can anyone give any advice on trying to trouble shoot this error?
> I've used Epicor help on it, but nothing useful there.
> The message detail usually says the ReportMonitor object had the exception. I can't say if it's always that, but it generally seems to be that issue.
> Exception caught in: Epicor.Mfg.BO.ReportMonitor
> Error Detail
> Message: Invalid session.
> Type: Error
> Program: manager/Session.p
> Method: Activate
> Table:
> Row:
> Field:
> Stack Trace
> at Epicor.Mfg.Proxy.ReportMonitorImpl.GetRowsKeepIdleTime(String whereClauseSysRptLst, Int32 pageSize, Int32 absolutePage, Boolean& morePages)
> at Epicor.Mfg.UI.Adapters.ReportMonitorAdapter.GetRowsKeepIdleTime(SearchOptions opts, Boolean& MorePages)
