V5 conversion
Data conversion is complete!!! Took about an hour!
Just an FYI...
Wanted to convert to v5 this weekend. Ran the install, it went
ok. Ran the idxbuild - took about 1 hour. Currently running
schema change which was started 2-4-01 at 2:30pm EST. Going
on 19 hours now. Had to bring v4 back online. Can't leave
the business down all day. I'll have to try again some other
day. Tech support says the schema change will probably take
a long time. They don't know how long. Neither tech support
or us knows if it is really still running.
database is 2.3 gigs, runnning on dual 700Mhz pentium3 with
1 gig ram. Crash protection is turned off.
Joe,
What is your harddrive configuration. When we ran our schema change (test
install) it only took a couple hours. Our database is 800 MB. This is
smaller than yours I realize but 19 hours doesn't seem right.
Sent: Monday, February 05, 2001 9:05 AM
To: Vantage List
Subject: [Vantage] v5 conversion
Just an FYI...
To unsubscribe from this group, send an email to:
vantage-unsubscribe@egroups.com
36G Quantum Atlas 10KII Ultra160 SCSI running on
an Adaptec 29160 Ultra160 controller.
"Keith . Mailloux" wrote:
> Joe,
> From: Joe Konecny [mailto:jkonecn@...]
> To: Vantage List
> Just an FYI...
I performed a V5 install on a test bed machine. I had to go from 3 to 5. I
recreated V3, Converted to 4, ran schema, then converted to V5 and ran
schema. From start to finish duration was about 6 hours, with no bugs. 450
Mhz pentium 3, 128 meg of ram, 130 meg data base, V5 schema finished in
less than an hour.
Shirley Graver
(End User)
Sys Admin
Rubber associates Inc.
Cleveland/Akron
Joe,
We had this same problem when attempting to load the
software on a test system. Started the schema change, came
back after the New Years weekend, and it was still running,
96 hours+. After talking with Mark Engemann, and Vantage
support, the best solution is to use a Provision option to connect
to the database. Do you have Provision? If you do, you can
change the connect options from what is in the schema change.vtg
file to -1. This allowed our schema change to run in about 2 hours.
If you have any questions, let me know.
Database is about 1 GB. Test Server Pent III 600 with 512 MB RAM,
single 18GB Drive, 100 Base T Network adapter
Tim Care
Electro Chemical Finishing
----- Original Message -----
To: "Vantage List" <vantage@yahoogroups.com>
> Just an FYI...
Ok... I started the schema change in single user mode and it
flew! It took about a minute! Now I'm running data conversions.
We'll see!
Tim Care wrote:
> Joe,
> Tim Care
> From: "Joe Konecny" <jkonecn@...>
> > Just an FYI...
