gpayne
(Greg Payne)
September 28, 2020, 6:29pm
2
There are two ways to do this. Warning if there are more than a transaction this can cause issues. I have done this with just a cost adjustment in parttran, but will refuse if they have received material and gone thru inspection.
method 1. UBAQ to unset has been used. Changing part UOM Conversion Factor - #14 by Jonathan
method 2 Which is also linked to in the above thread. Expose the override checkbox.
I found this KB article. Any risk in following the steps to allow part specific UOM? I remember that UOM changes in the past were very finicky… (but hoping that a part specific UOM would allow an alternate to be chosen - FT or ROLL).
UOM Part Specific Box Dimmed Unavailable KB0032735
Issue
Part setup has a conversion factor, and the UOM is wrong. Customer needs to change the conversion factor when the option is not available.
Resolution
Click on Inventory Management
Click on Setup
