I have 2 issues both regarding Lot Numbers. As I understand it there is no way to get rid of a lot number other than quantity adjusting it to 0.
First Issue: I have 3 separate lots that I need to adjust out. Somehow the quantity on these lots has 8 decimal places and the quantity adjust field only has 4. I even tried to cheat and directly copy the quantity from the grid into the quantity field. Gave me an error message about UOM only having 4 decimal places.
Second Issue: I have about 30 lots with part numbers that are not set to be lot tracked () that I need to adjust out but Quantity Adjust will not allow a Lot Number to be used on a non Lot Tracked Part.
Does anyone have any ideas how to get around either of these issues?
aidacra
(Epicor Employee: Nathan your friendly neighborhood Support Engineer)
3
I am sure that there are existing data fixes for these issues, or if not, that we would create them. Please submit a support case and we’ll get working on it.
I have attempted to use this workaround but every part where I try to temporarily turn on lot tracking I receive a “Track Lots cannot be changed because there is quantity in inspection.” error. I’m not sure why I’m receiving this as I’ve checked about every way I can think of and I don’t see any quantity in inspection.
I understand why Epicor do not allow Part tracked to be changed, there are many basic BPM writing lot no in many different tables, during many transactions, so after creating any of these records, changing this system flag will mess the data integrity, however if you have to, i am afraid that is the only way, to use SQL to update part lot tracked, then quantity adjust, then may be put this part on hold, and explain why on the description and hold reason.
The problem I am having is not being able to enable Lot Tracking and getting the
But there is nothing in inspection.
