Kinetic Dashboard - Field not showing in grid
Happening in K2025.2 and K2026.1 - SaaS.
I used the Dashboard Template shared on this site from the Insights presentation a few years ago (thanks Trudy) and have created quite a few dashboards with it. I’ve got a dashboard where I have multiple tabs on it, one tab is from a very simple BAQ - just the Part Table with fields from it. One of the fields I’m displaying is Part.UnitPrice in the BAQ. This was available when I had this BAQ in a classic dashboard. But, when I added that BAQ/Grid to a Kinetic dashboard, I’m getting all the fields from the BAQ EXCEPT Part_UnitPrice.
I’ve gone into App Studio, deleted the column in the Grid Model/Columns, then added it back in. I still can’t get the column to show up in the grid view, even though it’s showing it in the Grid Model/Columns settings. Anybody run into this?
BAQ Display Fields shown here:
In your Grid Model > Columns… try toggling this setting. There was another thread talking about “cost” columns not appearing. Could be the same glitch.
See if that brings it in for you.
Reference:
Bit me…
I set the “Disable Currency Toggle” to true, and it shows up in my grid.
Interestingly, you mentioned to “toggle” this switch. I assumed you meant to turn it on, then back off. I found those when I reset it back to false, it disappeared again. So, I have to leave the “Disable Currency Toggle” checked.
Thanks for the fix!
I just said “toggle” because I wasn’t 100% sure which way it was supposed to be set :laughing:
Glad it worked for you!
